FS: Large Heatsinks and Capacitors
This is a consolidation of my previous posts on these items. I've decided to split the lots and offer the items individually.
Capacitors, 12 Available
Nippon Chemi-Con U32D
68,000uF, 50V, 105C
2.5" diameter, 3.125" height
ESR 9.4 mOhm, 24.55A ripple current
Datasheet
$8 per piece + shipping.
Mounting clamps and terminal screws included. They are brand new and never used, but may need some reforming because they've been sitting around for a while.
Heatsinks, 4 Sets Available
Dimensions: 9 7/8" Width x 8" Height
Fins: 1" high x 30
Base thickness: approx 1/4"
$30 per pair + shipping. 3 pairs available.
Dimensions: 9 7/8" Width x 6 7/8" Height
Fins: 1" high x 30
$25 per pair + shipping. 1 pair available.
All the heatsinks above are the same aside from the latter pair being cut to a different height. These heatsinks were cut from a large piece so there are a few rough edges that could use some finish work. I've machined the base to be perfectly flat with a milling machine so there are machining marks that you can see in the picture.
Thanks to USPS flat rate Priority Mail boxes, anything you may be interested in will likely fit in either the $10.70 medium box, or the $14.50 large box.
