Due to setup simplification, I'm selling my beloved F3. It was professionally built with premium parts (Plitron transformer, Nichicon caps, vampire binding posts and rca, Furutech IEC) and has always behaved flawlessly.
Due to fixed transformer primary voltage and shipping costs I'm selling it to EU only. Shipping cost is 20€ to Italy and around 30€ for the rest of Europe - I can provide an exact quote with your zip code.
No need to provide further details on the circuit here
More photos available on request.
I'm asking 600€ plus shipping and Paypal fees.
Is that a Tim Rawson built amp?
Yes. Custom built (not bought from ebay). I had forgot his name.
then do it
and you can sell it for zillion dollars if you want , I don't care
If a buyer want it connected, I'll do it, no problem. The pictures are there to show all interiors.
In my setup, in two different houses, it has worked flawlessly for over 5 years. At least ONE connected equipment of the chain must have earth connection, like the preamp in my old setup. Hope this help clarify the thing.
If you want to open a debate about safety earth in audio equipment with a transformer and LPS, please do in the appropriate section.
I think you are confusing safety and signal earths. Safety earths are required unless the equipment is double insulated. Should a fault develop and live comes into contact with the chassis there is the risk of electrocution. If someone was to plug in an interconnect between an earthed preamp and your power amp with said fault condition they could be electrocuted. If I were you, I would pull the advert, earth the amp and relist it.
I am not trying to interfere with your sale but this easily remedied issue could land you in serious trouble if the worst were to happen. Make sure the earth has a good secure connection - plenty of advice online for this.
This covers it - Earthing (Grounding) Your Hi-Fi - Tricks and Techniques
While you're at it you might as well add insulation to all that exposed mains wiring around the IEC inlet, fuse, switch and thermistor. Exposed mains wiring kills.
Yeah, I'll put some isolation tape as well.
Have you tested it for hum since connecting the ground?
No, and I don't have time to do it. I have only tested the connections with DMM and everything is as it should be.
It's on sale in other places and I have received several contacts.
I'm guessing that the ground was left floating for a reason.
The reason being?
