Built from Baltic Birch (17.5" x 17.5" x 30".) The box is slightly undersized and sealed. The LF Boost of the BASH amp is utilized. Uses two 12" Dayton HF 8 ohm drivers.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=295-444
In a seperate chamber is a 500W BASH plate amp.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-752
Project is about 2 months old. Reason for selling: these drivers are unshielded and the ONLY place I can locate the sub is right behind my widescreen CRT. Needless to say, the two don't get along very well. (D'oh!!!) Going to start all over again with a shielded driver(s).
$400
Located in Tucson, AZ
$400
