Are these worth anything to anybody? I figure shipping would be about $7-$10 for the 48 states. These are all the same magazine, they changed their name a few times, especially in 1996.
the Audio Amateur - 1972 issues 1, 2, 3, 4
Audio Amateur - 1984 issues 1, 2, 3, 4, 5
Audio Amateur - 1993 issues 2, 3, 4
Audio Amateur - 1994 issues 1, 2, 3, 4
Audio Amateur - 1995 issues 1, 2, 3, 4
Audio Amateur - 1996 issue 1
Audio Amateur & Electronics - 1996 issues 2, 3
Audio Electronics - 1996 issue 4
Audio Electronics - 1997 issues 1, 2, 3, 4, 5, 6
Audio Electronics - 1998 issues 1, 2, 3, 4, 5, 6
Audio Electronics - 1999 issues 1, 2, 3, 4, 5, 6
Audio Electronics - 2000 issues 1, 2, 3, 4
cover articles include:
Supercharging Those High Performance Regulators by Walt Jung
Building the A40M Super Power Amp by Norman Thagard
Unveiling More Tonearm Mysteries by Dick Pierce
Designing the Ultimate MTM by Alden & D'Appolito
Build a Box That Does Not Resonate by Verhagen
Transmission Lines: Geometries & Alignments by Augspurger
Building Excellence: Stepped Attenuators
The Ins & Outs of Using JFETS
Designing the Best Input Stage
JFETs Try Em: You'll Like 'Em by Erno Borbely
Chuck Hansen Builds and Reviews Velleman's MOSFET Amp
More Ways to Overcome Amp Distortion
Where the Distortion is in Your Amps
Build a New & Better RIAA Checker
A Full Report On How And Why Amplifiers Distort
Ratchet Your DAC to the Next Level
PASS: Build Your Own Custom Op Amps
McClure: Build a Cheap Dummy Load
PASS: The Joys of Discrete Amps
GALO: Enabling Pitch Control for Your CDs
Build a Precise Sine Source by Chuck Hansen
Are Audio Double Blind Tests Really Credible
Build a Deluxe Passive Preamplifier by David Elderton
Custom Crafting a PASS A75 Amp
Build a Stepped Volume Control
Mixers and Mike Preamps Revisited
Build This AC Line Filter by Ken Swauger
Adding a Meter for IM/Distortion Tests by Chuck Hansen
Power Supply Snubbers Explained
Killing Those Turn On Thumps
Son of Zen Takes a Bride by Nelson Pass
Construct a Current Control Amplifier by Bill Chater
A Hybrid 26 Watt Current Control Amp With Tubes
The Ups and Downs of Powerline Conditioners
An Elegant Costume for Zen 2
Son of Zen Tow MOSFETs & Eleven Resistors
We Build Vellemans FM Tuner Kit
A Custom Preamp For Vinyl
Build a Feedforward Preamplifier
Dave Hurd's Gorgeous PASS A75 Amp
How to Make Easy Etched Circuit Cards
Understand Power Amp Feedback
High Quality Mike Preamps You Can Build
Building and Testing Super Power Supplies
Building Those Super Regulators
Incredibly Quiet DC by Jung
Bride of Zen
Picking the Best Resistors
Zen Again by Pass
Zen A Single MOSFET, Single Ended Amp
Sealing Out A-Z Potting by L.B.Dalzell
Upgrade Hafler's DH220
Modular Power by Borbely
Line Garbage Redux by Galo
Diverting Disaster
Log Periodic Dipole Array
Smart Cooler
Decibel Meter
Stalking True Ambience
Belt Drive
Erno Borbely's Two 100W MOSFET Amps
microphones, unique amplifier, & speaker tuning
An Electros Static Speaker System
Building a 10 1/2" Reele Tape Deck
A Simple Shock Mount for Your Microphone
There are more articles than I have listed. The ads in some of the older issues are also interesting.
I also have about an equal number of Speaker Builder magazines.
Bride of Zen
Zen Again by Pass
Diverting Disaster
Smart Cooler
Decibel Meter
Belt Drive
heads up on SB mags
When the this transaction is complete, I'll be offering these next:
Speaker Builder - 1993 issue 1
Speaker Builder - 1994 issues 1, 2, 3. 4. 5. 6. 7. 8
Speaker Builder - 1995 issues 1, 2, 3. 4. 5. 6. 7. 8
Speaker Builder - 1996 issue 1, 2, 3, 4, 5, 6, 7, 8
Speaker Builder - 1997 issues 1, 2, 3, 4, 5, 6, 7, 8
Speaker Builder - 1998 issues 1, 2, 3, 4, 5, 6, 7, 8
Speaker Builder - 1999 issues 1, 2, 4, 5, 6, 7, 8
Speaker Builder - 2000 issues 1, 2, 3, 4, 5, 6
Testing 18 Shapes For The Ideal Midrange Box
How to Match a Big MTM With an Overstuffed Sub
Building Two-Way Monitors and Room Treatment to Match
Resolving Two-Driver Desig Mysteries by G.R. Koonce
Building That Super Dream Loudspeakr by Alden, Chaleff, & D'Appolito
Transmission Lines: Geometry & Alignments by Augspurger
Rescue for Advent's 10" Woofer by Yeago
Engineering the Ideally Dimensioned Listening Room
Stuffing Transmission Lines: Which Stuff & How Dense? by George Augspurger
Easy Speaker Hole Cuts With Jasper's Circle Jig
Exploring the Practical Details of Transmission Lines by G.L. Augspurger
Using Ancient Proportion Ideas For Your Speaker Box
Mate Big PVC Pipes & Ribbons
An Easy Trick For Setting Driver Offsetts
A Simple Impedance Checking Tool
Constuct This Unorthodox Single Chamber Subwoofer
Sleuthing Out Performance With Your Computer
We Test Drive The Seas Odin by Mark Florian
A Bessel Box Subwoofer by Les Mertz
What Sort of Walls Are Best For Boxes
Mating Satellites and Subwoofers For Best Location and Imaging
Building Feedback Into the Driver
Do You Need New Speaker Cables
Constructing a Midrange Horn
What Makes One Driver Better Than Another
How transmission lines work: Finall The Full Story
A review of Speaker Design Fundamentals
Building a Single-Driver Full-Range Horn
Jelly-Jar Feet For Your Isolation Problems
Build a Small Footprint Thre-Way WIth Isobarik Bass
Gilding B&W's Economic Two-Way Monitors
Taking the Drudery Out Of Third-Ocatve Measurements
Rebuilding the AR-3a by Tom Yeago
How to Solve the Placement Mystery by Raczynski
Trade Secrets: Cones, Suspensions & Spiders
Build This Double-Chamber Reflex by Paul Sechi
Construct a Smaller, More Powerful Isobarik by Paul Kittinger
Building a 3-Way Pyramid
Designing High Order Filters With Minimum Phase by Tim Sandrik
Let Your Computer Locate Your Speakers
Build a Curved Array With Nine Electorstat Panels Each by Bill Waslo
Upgrading the Woofer For a Bigger Listening Room by Philip Abbate
How Good/Bad Are Your Room's Acoustics?
Unveiling Complex Impedance Secrets
The Force: A Powered 4-Way With Servo Bass
How to Rescue Valued Drivers From Foam Rot
An Easier Way to Design Passive Crossovers by G.R. Koonce
What Ferrofluids Do For Drivers
We Test a Digital Room Correcting Preamp
Taking the Bounce Out Of Front Panels by G.R. Koonce
Electrostatics Aimed at Your CHair by BIll Waslo
Design A Studio With Invisible Walls
How to Manage Group Delay Distortion
Build a 3-Way With Very Little Sawing
Qqueezing Your Driver For Max Performance
Waveguides For Deeper Bass Revisited
Getting That Resonance Peak
Finding Exact Mass & Resistance For Your Driver
Rules of the Road For Building Great Loudspeakers
Build An Electrostatic With Insulated Panels
Building A 3-Way Isobarik Tower
Shelving Tricks For a Tough Room
Can Electronics Correct The Phase Errors?
Meet The Snail Horn A Reflex/Horn Hybrid
Let's Dump Damping Factor by Dick Pierce
The Ins and Outs of Resistance in Crossovers
Plain Vanilla Filtering by Reg Williamson
Putting Music On The Beach
Build a Reflex/TL Combo
The Super Simpline: A One Evening Project
Speaker Stands For Satellites
A Balanced Response Speaker
Build An Active Crossover WIth Vacuum Tubes
A Big, 3-Way Transmission Line Speaker
An Elegant 2-Way Active & Adaptive Crossover
Ultra-Simple Active Crossovers WIth Two Microchips
All you ever wanted to know about Capacitors
Getting more accurate data on those drivers
A Quarter-Length Transmission Line
Building a Big 40" Planar
Choosing and Using Coils
Quick, Easy-to-Make Pipe Speakers
How to Make That New Box Beautiful
Concrete-Walled, With Four Drivers For Big 20-HZ Bass by Tom Perazella
How to Invent a New Dual-Modulus Material for Speaker Walls by Hajo Prodan
Build This Extraordinary Low-Cost Three-Way
Should Woofers Point Downward?
A Big 15" Subwoofer
Stroboscopic Checks on Spider Action
How To CHoose A Good Crossover Coil
Build a Barrel of 9Hz Bass
Building the Low-Cost 3-Way Miracel SPeaker by Koonce & Wright
Time, Frequency, Phase & Delay by Bill Waslo
Gonzalez & Colin vs. Moncrieff on Capacitor Performance Claims
How to Get System Phase Absolutely Right
Wrestling Good Stuff From Piezo Drivers
On Voltage, Power & Efficiency Puzzles by D'Appolito & Pierce
Super Smooth the Box Sans Sanding
New Focused Array Tricks
Speaker Stands You Can Make
Making Odd-Ball Driver Cutouts
Deep Bass With Tiny Drivers
Handbuild a Concrete Midrange Horn
What Heat Does To Your Drivers
Layout and Cutting For Large Panels
Build a Pair of Ribbons
Fasteners Galore
Build a Dream 15" TL Woofer
Inductor Geography in Crossovers by Sanfilipo
Dressing the Box For Company by Wayland
Demystifying Damping by Jenkins
Using Biscuits For Great Corner Joints
The System III An Elegant Four-way Design by D.E. Stenton
Conquering Impedance SPeaker Drivers Aren't Resistors by Victor Staggs
Build a 16 Hz Woofer by Pike
P-Spicing a Great Crossover
MTM Dipole With a Sub
Better Sonics For Church by Bacon
Upgrades For Vintage Magnepans by Seymor
Electronic Crossovers Galore by Borbely & Gaertner
A Big 15" Subwoofer
Fasteners Galore
