FS amplifier parts: film caps, electrolytics, relais and firstwatt F2 boards
As some random idiot destroyed parts of my motorcycle, I am trying to cover the repair costs partially by selling some parts collected in the last years. Feel free to make me a fair offer if you are interested in more parts:
  • Cornell Dubilier film caps 30µF 600VDC UNL6W30K-F, 35mm diameter, Digikey 338-1370-ND, 2 slightly used. Each 8€
  • Epcos film caps 68µF 100VDC, 6 unused, Farnell 2468904. Pair 8€, one pair left
  • Epcos film caps 82µF 63VDC, 4 unused,Digikey 495-4579-ND. Pair 8€
  • Epcos film caps 110µF 450VDC, get rid of electrolytics in your tubeamp with these caps! Digikey 495-3944-ND, 1 unused, 2 had been soldered. Each 10€
  • 5W high voltage output isolated dc/dc converters from RECOM with 12V input (R12-150B) and 24V input (R24-150B). Output voltage up to 200V and output current up to 50mA. Switching frequency is 200kHz and thus not audible. Two units can be cascaded for higher output voltages. Each 15€
  • Meanwell 24V 4.5A switching supply, S-100F-24. 10€
  • Chemicon 250V 22µF SME, bag of at least 80 pcs. 10 pcs. 1€
  • Chemicon 200V 100µF SMG, bag of at least 35 pcs. All 5€
  • TQ2-12VDC Panasonic relais for DCB1, 10 unused in Farnell bag (1200949). All 10€, sold
  • BUF634T buffer, TO220-5 package, BurrBrown logo, 6 in unopened Digikey bag. All 20€, Sold
  • Firstwatt F2 Boards, as shown, without power transistors (unfinished project). Both 30€, Sold
  • Cornell Dubilier film caps 50µF 750VDC UNL7W50K-F, never used. Diameter 50mm, height 63mm, Digikey UNL7W50K-F-ND. Both 25€, Sold
  • Vishay film caps 560µF 63VDC, MKT1820 series, unused pair, ideal as cathode resistor bypass, Digikey BC3179-ND. Both 70€, Sold
  • New and unsoldered high quality Elma 01-1264 swiss made rotary switches with 2 poles and 6 positions with gold plated solder lugs. Each 17€
If you need more detailed photos or information, please contact me. You may find the corresponding datasheets by using the distributor order code. Please add shipping costs from Germany. Shipping for small parts usually only 3.70€. Paypal via "friends and family" only unless you add the transaction fees.
1) Cornell Dubilier film caps 50µF 750VDC UNL7W50K-F, never used Both 25€
2) Cornell Dubilier film caps 30µF 600VDC UNL6W30K-F, 35mm dia 3 unused, 1 slightly used. Each 8€
3) Vishay film caps 560µF 63VDC, MKT1820 series, unused pair, Both 70€
4) Epcos film caps 110µF 450VDC, 4 unused, 2 had been soldered. Each 10€
5) Elma 01-1264 2 poles and 6 positions with gold plated solder lugs. Each 17€
I'll take all listed above, note partial qty in bold red.
If you'll ship Free to Texas USA 78133 (your choice of carrier)
Charles
