FS amp cases
I have 2 amp cases for sale. They measure 16" w 14" d 6: h
One of them housed a Pass A40 but with it disipating 200w
it ran too hot so I scaled it down to a 20w version of the A40
with 100w disipation which it handled fine. In one of the photos
you can still see the 3 pair of output devices still mounted.
This case is a little rough. It has 2 removiable rails that bolt to the heatsinks drilled for 3 pair of TO3 devices per rail.
The other case is the same except the transistor mounting rails
are drilled for only 2 pair of to3 devices per rail. This one still
has the power supply and one chanel of the DEAD amp. This
power supply is + - 65v at ~500va.
I would prefer to sell these as a set for $150 + shipping from
30290. I will remove that transformer if you don't want it as it
weighs about 20lb and will make the shipping a lot higher. This
is a firm price no trades.
