FS: Alps RK27 motorised volume pot with remote controller PCB ready to fit in amp
For sale is a remote volume control ready to install in Pre-amp or Amplifier. Purchased 14th June 2004 and from an unfinished project. Items supplied:
Alps (Blue) RK27112MC motorised dual log 50KAX2 potentiometer, ø6mm shaft x 13mm long (20mm long back to mounting face including thread). Shaft is round and has no flat machined.
ø28mm x 14mm anodised solid aluminium knob with grubscrew fitting.
Remote controller PCB (57mm x 74mm) with all components fitted, LEDs, sensor and tested. Requires 9-15VDC 70mA power supply and operates via Philips TV codes. You need a universal remote control that can be programmed for a Philips TV (Philips Sat, VCR, CD can also be used but with PCB mods). The remote controller operates volume - up / down, precise volume - up / down, mute function.
A red ø10mm sensor window is supplied for fitting to the amplifier front panel.
AU$95 shipped to anywhere in Australia.
Thanks for looking.
