I have for sale 11pcs PCB's for TPA3106D1 40W class D amplifier from TI. PCB is made as dual mono, but can also be cut in half if needed, size is 71mm*66mm.
It is actually same board as the one on the link with some mods, so better input and output caps can be used!
Price for one PCB is 10€(worldwide shipping included)!
TPA3106D1
Regards,
Ales
TPA3106D1
Regards,
Ales
Hi there!
Since there were many inquiries about this PCB I have made another 10 of them. This time PCB is designed in such a way that you plug in signal, power and speakers and you are good to go. Price remains the same.
BR,
Ales
BR,
Ales
The solder mask of one of the thermal pads (upper side of PCB) seems to have gone wrong at production.
Yes, minor design fault, but it does not effect the functionality. It would be bigger problem if this would have occurred on bottom side.
