Frequency Counter Project Help
I built this 50Mhz Frequency Counter Circuit:
http://www.sixca.com/eng/articles/fc50/
I download the source code at the bottom of the page.
It contains both .asm and .hex files.
I'm using the same exact chip, PIC16F84A. I'm using MPLAB 7 and the Olimex ICD2. I have programmed the pic, verfied it it has programmed. tried a blank check, erased the part.
When I power up the circuit, I get no text. I'm using a 16x2 character LCD module. The pinouts are exactly the same as the 16x1.
At this point, I'm not sure if I have programmed the chip properly.
I open the hex file, set the device to PIC16F84A, OSC XT, Watchdog OFF, next two settings ON,ON.
I have tried opening the .asm file and compiled it but I get bank 0 errors. I don't know any assembly to fix these bank errors.
Also, the schematic says Adjust R3 for 5Volts here. I'm not sure which point they are referring to and I think they meant R5?
Thanks for your help!
okay, I got it sort of working. I just need help on the assembly code, some minor tweeks.
When I power up circuit, the LCD comes up with a 'P' ,00 IHx,
the Hx instead of Hz.
It is able to display the frequency but only 4 digits, example:
1491 Hx
I'm using a 16x2 display so something is off. Here is the link to the 16x2 module:
http://character-lcd-lcds.shopeio.com/inventory/details.asp?id=932&cat=Lcds&sub=Character Lcd
Attached is the source code.
Thanks for your help.
  • 50mhz.txt
