I dont even know what this is, but im going to give it to anyone who will pay shipping (about $10 - 14 for expedited to the US)
no response in a few days and its going to be scrap.
I'll take it.
ps. It's an ortofon rs 212, and it's worth at least a few hundred dollars.
so, I'll take it providing you still want to give it away.
well it does not have a lifter mechanism or anything, and there is a threaded hole in the back with nothing in it.
you probably have to do some tinkering.
Screw it im gonna send it to you anyways someone on a different forum sent me a free Pulsar 1 board to replace a broken one so im paying it forward.
all i request is that you are going to use it and not put it on ebay.
D to the g is absolutely correct that this arm is an Ortofon RS-212, guess you did not look hard enough - then again without knowing how could you find out?
Anyway here is a link that will put any doubt to rest:
http://www.vinylengine.com/library/ortofon/rs-212.shtml
You will find a link to the manual on the above page. Direct links to it will not work.
Well i hope you are good at tinkering, i have no idea if the internal wiring is still good, and it has no headshell, and maybe a part missing from the back (optional?) it seems the lifter was optional as well because this one has a plug where the lifter would be.
I seem to remeber that around the time when this was made, ortofon had cartridge that plugged directly in the headhell connector, so its probably a standard one.
cant wait to see it get a new life!
