Well, almost free. I'm thinking perhaps $4 for shipping, USPS priority mail or such like.
A few items that I don't have the time or inclination to mess with, perhaps someone out there would like too:
1) A few of the receiver boards from an Accurian amp. If you have a transmitter you know how you can use these. They are self powered, and simply output an audio signal from the transmitter.
2) Fisher pre-amp board
2) The pre-amp section of a Fisher integrated amp (CA2320) I am presently gutting to transform into a quad 405 clone. Included is the printed circuit board with all the input sockets, the knobs and front panel.
The power supply regulator for the pre-amp is part of the power amp boards that are listed in the next entry. I will give priority to someone that wants the power amps and the pre-amps, since they will have the best chance of getting it working.
I have no idea if the pre-amp works, the power amps did not when I tried them.
Stuart
Stuart
3) Fisher power amp boards
These are the 2 power amps from the integrated amp mentioned in the last entry. They are not identical, one channel has regulators for the pre-amp, the other has the output protection relay etc. So I can't be certain but I think maybe you end up using both or nothing...
The picture is of the channel that has the pre-amp regulators.
When I tried these they did not work, I didn't spend any time diagnosing them, so you guess is as good as mine as to whats wrong.
Stuart
Stuart
