We've finished putting our sub woofer together and have no use for one of the early test bed cabinets that I constructed.
It's built from 25mm MDF braced internally at the corners but measuring in at 40cm[d] x 40cm[w] x 50cm[h] is quite rigid.
There are cut-outs for driver and amp module, though with some deft routeing you could blank the hole / holes with 25mm MDF and cut out your own sizes.
Currently it will accommodate a 12" [305mm] amp panel [Keiga KGND 52100] and a 12" driver [Shadow Works - Titan, Phantom, Bronze, Genesis] with cut-out 282mm and rebate 322mm
It could possibly be finished with a bit of elbow grease and some TLC.
Images below.
Free to someone who will collect from OX9 3JF
Images below.
- Subwoofers
- Free subwoofer cabinet for collection
