I want to recommend one full range driver named FR88EX here.
The motor is an underhung neodymium design and the cone is thin (and fragile) formed aluminum. The only negative is a slightly ragged top end that may take some filter work if used full range, but I'd generally recommend a cheap and small neo tweeter placed close and crossed over high. There's a lot on the positive side, like high sensitivity, a clean low end and smooth midrange response. The frame is cast with ventilation under the spider, but users will have to pay close attention to airflow behind the cone - It's even more important to chamfer the inside baffle opening and in this case likely use a thinner baffle material as well.
More details pls see Products_Fountek Electronics Co.,Ltd
Any further help pls contact:
Evan
E-mail:evan.zhu@fountek.net
MSN:Fountek_Evan@hotmail.com
Evan
what's quantity will you need?Thanks Evan - looks like an interesting driver.
I have a friend who will be using this in an open baffle design with an 18" woofer under it.
The design may be posted on diyAudio if it works out.
Do you have contact info?
Evan
Thank you DaveI'm currently breaking in Twins in repurposed uFonken^2 boxes.
dave
what's your contact info?we can contact by E-mail,MSN orthers if possible.
Evan
Great speaker. Here is what I built.
Cool, is that the Martello plan? If not, can you post the dimensions?
- Vendor's Bazaar
- FR88EX
