marchel said:Does the fx120 sound better than the fe127?
From all reports. One would also hope this is the case given the price differential. I have a pair breaking in to play with.
Can the fostex fx120 be use on the PAWO cabinet that could be found in Planet10's site? Will it work properly in that cabinet?
I haven't had a chance to really crunch the numbers or measure the drivers. Factory specs put it really close to the 127.
That the PAWO works with the FE127 is a fluke... it was not designed for the driver... you might look at some of the designs specifically targeting the FE127 -- the Mileva was designed to filt a similar form factor.
dave
To my ears, the stock FX120 is a huge improvement over the stock FE127E.
