Fostex full range
Hi Guys,
Ive been using smallish stand mount speakers in my 5m by 3.5m room.Ive been reading lots and lots of posts on this great forum about Fostex full range speakers.Have any of you gone from stand mounts to full range floor standing designs and what can i expect?
I realy love imaging and a realistic soundstage and realistic dynamics ,hense my desire for either the Fostex FE168E Sigma
or the smaller FE108E sigma .What do you think of Fostex's own cabinate designs.They have unusual steppped horns! Would it be an improvement to use a smooth piece instead of these steps.
My main question is which box to build for my room , the 108 or the 168 sigma.I dont want to have an over big unfocused sound,as i said i like a nice stereo image.Bass, i like well defined too....many thanks ...james:)
Jamesuk1 said:
Hi Guys,
perhaps You might find this of interest:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=123132
the picture of the cabinets I use with FE206E is here:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=121385&pagenumber=1
best,
graaf
I've been using smallish stand mount speakers in my 5m by 3.5m room. I've been reading lots and lots of posts on this great forum about Fostex full range speakers. Have any of you gone from stand mounts to full range floor standing designs and what canI expect?
Yes. No crossover in the midrange = good idea generally & improved transparency. For the rest it depends on the cabinet as to what you're going to get. A floorstander can mean sealed, BR, TL, MLTL, horn / hybrid horn... all sound different in just about every possible area, so it depends what you value sonically, what the rest of your room & system are like, and what kind of material you play most often.
I realy love imaging and a realistic soundstage and realistic dynamics ,hense my desire for either the Fostex FE168ESigma
or the smaller FE108ESigma.
Imaging is something FR units do well. Soundstaging -well, it depends on the enclosure you use, and how you define 'realistic.' Dynamics... in the midrange, certainly. Huge bass transients in heavy rock, large scale classical pieces where you get large dynamic swings = no chance. Especially not with the 108. There's a limit to how much air a small cone can shift, even with horn loading. There's no subsitiute for multiple 15in woofers when it comes to that side of things.
What do you think of Fostex's own cabinate designs. They have unusual steppped horns!
They're usually OK and sometimes worse. The ESigma enclosures aren't bad, but you can do better generally. Depends on how big a cabinet you can stomach really. Series manifold expansion isn't particularly unusual; Olson first suggested it in the 1930s & that style of design has been very popular in Japan for a long time, primarily thanks to the late Tetuso Nagaoka. I've designed quite a few myself, some of which are on the frugal-horn site at www.frugal-horn.com
No. What I call a staight series-manifold cabinet is (or should be) designed somewhat differently to a more regular continuous expansion enclosure. Smoothing it out will loose some of its advantages without gaining you anything worth having.
My main question is which box to build for my room, the 108 or the 168ESigma. I dont want to have an over big unfocused sound,as i said i like a nice stereo image. Bass, I like well defined too...
Well, I wouldn't build either, but if you must, I'd go with the 168. The 108 struggles when you get near 100Hz. I wouldn't personally use it without supporting woofers.
HM,
I have heard bad things about running the speaker wire through the horn path. Seems like it would be easy to run it up the back and just through the top section for the forward facing driver and just a direct conection to the rear one. Have you tried it this way? If so, was there an audible or measurable difference?
BTW, I do like the rear wave shaping on that one driver.
Re: thanks guys
Jamesuk1 said:
Thanks guys ,if the fostex enclosures arent very good,what are?
i think i will go with the FE168e sigma for a bigger sound and .......some bass....James
Hi James,
For a simple build the BIB's are really nice and provide the lows better than most of the others. Don't let the simplicity fool you ,they work really well and should be in, or close to your room corners.. Look to Godzilla's site zillaspeak.com.
Also for some more refinement but harder build than the BIB, look to Planet10's site for the BVR's and such.. Dave:)
Added: http://www.zillaspeak.com/bib.asp click on Fostex
http://www.frugal-horn.com/ look to see what works for your driver choice etc..
Hello, gurley123
always glue a wire along walls, corners, the foto is not finished.
"was there an audible or measurable difference?"
no really, a double blind test shows wire is not listenable,
not measurable, but for example i prefer no binding posts.
less is more
168es's BIBs
Hi James, I was in a similar situation to you, similar room and existing speakers were standmounts(Dynaudio 1.3se) I liked what I read on this forum about fullrangers and built a pair of BIBs for the 168es a few months ago. I think they are slowly pushing the Dyns out the door. They dont do everything better but they do alot right. They have a big sound stage and image well but not quite as three dimensionally although this may be due to higher frequency leakage out the mouth which can be corrected. The soundstage they have does'nt distract you with its 'hifiness'. They dont have the weight in the bass and midbass (may be an amp/cable issue?)but they do go very low (28-30 hz)and very cleanly, avoiding boomyness pretty well completely. And depending on what you speakers do in that area they may well be an improvement. They often make instruments sound very beatiful with rich tonality(more a full range than a BIB thing I guess) and are coherent across the spectrum giving a very easy and live sound. And they are incredibly dynamic, putting life back into even the most dreary CD's.
So they image not quite as specifically as my standmounts but probably more appealingly; bass....dont worry!, and there are big plusses in other areas.
As others have noted the BIB is an easy build and great bang for your buck but big: I'm interested in the BVR designs for this driver as well; they may be more refined and sizewise I may be able to live with them longer. Hope this helps, regards, Andrew
Might try Half Changs
Hi, pebbles , Those Bibs looks realy good but i couldnt live with there size. too tall . I have read about the Half Changs .Will a Fostex Fe168e Sigma work in it with modifications.Some people fit an eq circuit to there horn designs ,would this need one do you think?
I realy like the size of this half chang as it would look just right in my room.What do you guys think.I listen to Jazz classical some rock ie pink floyd etc,lots of vocals too....thanks ...James
Re: half changs or curvy changs
Jamesuk1 said:
Almost sure now either half changs or might push the boat abit and go with the curvy changs if they are better,the curvy's frequency plot with 167e looks very smooth.Would the 168 sigma be similar....james
No, not as-is. I designed them for the FE167E. A cabinet is designed for a specific driver; it's generally not a good policy to try stuffing other drivers into them. Fortunately in this case, you're lucky because this type of cabinet tends to be quite forgiving of the driver. So, if you wanted to use the curved KimChi, you can: shorten the throats to 1.5in long instead of the current 4.0in & you should be good to go.
A point. Don't know if it's relevant or not to you, but worth keeping in mind: the curved-front cabinets utilise focused radiation. They are designed with a particular listening distance in mind (11ft or more). Closer & they won't work as well -you'll have a very small sweet-spot. These are selfish speakers. They aren't unforgiving, but they're really intended for one connoisseur. Jeeves -the bandy and cigars, if you please. ;)
Re: Re: Thanks
graaf said:
well I say - move those racks! :D
move everything else too if necesary
for if You really love realistic soundstage, realism in general, this the solution for You
Doesn't that depend on how you define 'realistic?'
Personally, I'm not that sold on omnis -I find the proportion of reflected - direct sound somewhat too high for my liking. OTOH, some find direct radiators / horns present too much direct radiation & too little indirect for their preference. All depends on what the individual values most.
