Yep. The 15 litre bass reflex Fostex recommended enclosure for the FE167E can be found at this link.
http://www.fostexinternational.com/docs/speaker_comp/pdf/recom_enclose/167e_enclrev.pdf
Here's the thread on the Insignia speakers.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=81277&highlight=
I wouldn't think you'd get anywhere near the FE166e's potential in these boxes. They don't do particularily well in BR and these would seem a bit small to even try (anyone know the volume?). FE167e would on 1st pass be a better fit, porting would likely need adjustment.
-------yes, it does't get out the full potential of Fe166E . use it with a subwoofer, and set the LFE to 200hz in Denon receiver , so this insignia box with fostex speaker only take reponsibility of > 200hz freq.
dave
mslxb said:yes, it does't get out the full potential of Fe166E . use it with a subwoofer, and set the LFE to 200hz in Denon receiver , so this insignia box with fostex speaker only take reponsibility of > 200hz freq.
You'd really need stereo woofers then. As well, AFAIK, most HT recievers typically have a max XO of 120 Hz.
dave
