Hi. I plan to make FE206NV2 backloaded horn. The specification sheet gives a blueprint for it. I already ordered 18mm plywood with cutting to dimensions. My questions is how to assemble it?
I am not a professional carpenter, but I have some experience. I made several cabinets however I used screws in assembly. In this project I want to use only glue (Titebond).
So is it ok to make it without screws?
In what order do you suggest I should asseble?
I also want to protect it with varnish so moisture will not influence the plywood. How to apply this varnish inside?
Any advices are welcomed.
PS. I have different types of clamps (I haven't bought 1200mm ones yet, but they are in process) and also bought a pair of clamps for a corner.
Dave, thank you for the response. I hope I will finish this project first and then do betterNote that the Fstex factory horns are mediocre at best. You can do better.
dave
Can you please point to the mods?
