Hi everyone
I'm new to the site
I bought flat pack enclosure for fe206 full range and I have the drive units
Cabinet is recommend by fostex itself but I couldn't find any info
about do I need to use any damping metarial inside the cabinet if so how?
If someone help me with this I also making bass reflex cabinet for fostex fe103 again same question
Thanks in advance
I'm new to the site
Thanks in advance
I always like to buy some extra wool or acousta stuff for fine tuning speakers. For the back horn start with some behind the driver and listen. Add or reduce depending on what you hear. Sometimes i've stuffed up into the mouth of the horn depending on how hollow things sounded. I'd also stuff the ported box a little too to reduce back waves against the rear of the driver. Enjoy your projects!
