fosgate g250_a2 bias problem
hey perry,
alright, the right channel is the problem child.
i have a 1v p-p signal being applied.
the first pic is the left channel output, 10v p-p.
the second pic is the right channel with same input applied but at 2 volts per division.
i have 4 ohm resistors on the output.
i'm a little baffled right at the moment.
belay that last post about the 5v p-p output, i apparently had the left channel gain set up higher than the right channel.
both outputs look good. now to adjust the bias.
got the bias adjusted.
eta:
pic is the left and right output at 5v per div.
