Forte' audio model two preamplifier
Wow. Rayma you are a genius. No noise when I spin the record manually. It's appear noise is generate by the motor itself.
Now... How to solve this problem? A faraday enclosure around the motor or simply replace the belt?
cdebien. If your turntable uses an ac motor, try replacing the motor capacitors, they could be old and out of spec. This cured hum in my old turntable. Make sure the capacitors are of original values.
