For sale Pass DIY F5 amplifier.
Pass DIY F5 stereo amplifier.
UK only due to its weight.
Includes DIY Store PCBs, all fully populated and tested.
Fitted in 4U case with heatsinks.
Power switch, power sockets, input RCA connectors and LS terminals fitted and included.
Partial PSU. Transformer is not included unless you pay for it (+ £35)
Sensible offers over £100 please. The parts alone are worth over £200.
Collection from B98.
The Photos
There is a 600VA transformer but that will be reclaimed unless you want to pay for it. PSU caps are not big enough, the PSU needs a serious re-vamp.
Please don't ask for parts of it. It comes as an almost finished project.
It has been run and fully tested. It's all set up ready to go but the cheap caps are too small for a Class A amplifier.
There was a pre-unreg PSU prior to the cap board. This has been removed and used in another project. Hence there is no recitfication after the transformer.
This amplifier needs SERIOUS CRCC PSU. 42000uF per rail was woefully insufficient.
I say again, transformer will need to be negotiated separately otherwise it will be removed.
I use Aleph Mini every day (with seriously attenuated input signal) which sounds better than my ACA but sound pressure wise ACA was really enough 98% of the time... Still I can imagine that bigger Pass amps would be better even at my low volume level listening. So I was tempted to try. But you probably don't buy a brewery when you want to taste a beer.
