Would anyone know what kind(size,where to get,etc)speaker binding posts? I had received
2 from China but they were too small.....on the Adcom the posts are quite a bit bigger.
Can you post photos of your Adcom posts, and the holes they mount in?
This is the type II amp.The speaker posts are on little black plastic standoff's...inside and out of cabinet'
Adcom 5400 photos - Google Search
this is what i found.I think this is the same size as what i got from China
that may not have went thru...try againhttp://www.mouser.com/ds/2/159/2417073_6883_6884-58686.pdf
The ones i received are definitely smaller than what is on the amp!!
OK.....yes.....it is 3/4" center but the ones on the amp are longer and much beefier...
There likely are two round holes 3/4'' apart, but you still need to know the hole diameter to find replacements that will fit.
There are many brands, and the ones on the amp may no longer be available. The style with a base is for antirotation,
like these have. BP21-2RRN-BPKG-SUPERIOR ELECTRIC-Datasheet
- Design & Build
- Parts
- For Adcom 5400 power amp-need speaker binding posts
