Focal Polyglass woofers and Vifa tweeters enough for a home theater speaker project. Enough drivers to make MTM left, right, and center speakers.
The 4 Focal woofers for the left and right main channels are the 8V 412DB these are dual 8 ohm voice coil drivers and will result in 16 ohm when the voice coils are connected in series. That makes your MTM an amp friendly 8 ohms. These should be crossed over around 2k or so.
The 2 Focal woofers for the center are the 6V415 which are 9 ohm drivers and these can be crossed over a little high up to 3k
Both of these woofers are the high quality Focal polyglass cones with cast frames, raised spider, vented pole piece. They have a very smooth roll-off and no large response peaks so crossover can be simple.
The tweeters are the Vifa D26TG-35-06 used in many high end projects
I have the manufacturers data sheets for both including the response charts and will send them with the speakers. I could scan them and email them if wanted first. I can also send pictures.
These drivers are un-used, I bought them for a project that I did not find time for. Original cost was around $500
Will sell all for $300 plus shipping
