Fisher 400 Tube Tuner/Amp fpr Sale (in Europe)
Fisher 400 Vacuum Tube/Valve Tuner/Amplifier (fully serviced)
Fisher 400 Röhren Tuner/Vollverstärker (völlig wiederhergestelt)
Fisher 400 Ampli a Tubes
Classic of vintage Hi-Fi audio, 100% vacuum tube FM tuner/amplifier (1964 g).
Excellent clean and warm tube sound, not comparable to cheap plastic junk.
Very good condition for its age, clean front panel (no scratches and dents), all letters and writings present, all controls and knobs original and working (incl. coupled volume<->power on switch), no rust on chassis and transformers. Volume control a little bit noisy due to 44 years age, all other controls are absolutely clean. Amplifier have no cabinet (was installed in console). FM tuner requires external antenna for clean, noise-free reception (not included). Cabinets of desired color can be purchased separately.
2x25W RMS, 2x30W (Max), FM Tuner (no AM), Line, Tape and Phono inputs,
4/8/16 Ohm output. High-sensitive (95 - 98 dB/W/m) speakers very recommended.
All vacuum tubes vintage:
7868 Sylvania
12AX7 RCA
6AU6/6HS6/6AB4/6HA5 Fisher/RCA
Tubes used but all workings fine.
Unlike partial restoration, which includes only replacement of silenium rectifier, coupling capacitors and broken tubes, this unit is REALLY FULLY SERVICED:
1) Replaced silenium rectifier, old diodes, and ALL electrolytic can capacitors in power supply and filter.
2) Installed new coupling capacitors (film/foil polypropilene and paper-in-oil).
3) Installed 4 pcs of 10 ohm cathode resistors (in order to protect audio transformers).
120V, requires 220-120V converter in Europe, at least 600W. I can give away main, but it is very heavy, and does not make any sense to ship, will be cheaper to buy it locally.
Unit is guaranteed to work at the moment of pickup. However, due to its age, I cannot give any further warranty. Sold AS IS. No Return.
Shipment all across Europe, but local pick up preferred (unit is very heavy - 14 kg, and fragile - top open).
Amplifier will be packed with great care prior shipment, vacuum tubes will packed separately for safety reason.
Payment: money transfer, PayPal (no extra charge), cash on collection.
Shipment cost by DPD in Europe approx 35-50 EURO.
If you have any questions, please do not hesitate to write (preferably in English).
andrei - dot - verovski - at -gmail - dot - com
