Banned
Joined 2002
Here comes the pixs.
Pixs one show circuits 8 months ago, with 2 passive ccs & 1 active ccs.
pixs two currently in use for 2 months now.
pixs three power supply in use round donuts & square iron.
How does it sound?
To describe it, is not easy both power supplies give u different presentations, Donuts sound fast and dynamic but lacks the warmth that comes with sq. iron, that why tubes amps still uses sq. iron. U build it and listen for yourself. Next steps taking it up to the limits.
How does it sound?
Sometimes it is better to do it this way. 1. It is fast and easy . I save the cost on PCBs and puts in more components. 2. When the circuits is first tested it is easy to change components that start to drift apart. U will notice that i have caps. of about 10Kuf. in total.jh6you said:Very impressive rail ways and stations . . .
Lets talk about how its sound. 1. When used with Aleph 5 its sounds fast, deep and spacious, back ground details is wonderful clear like u never heard before. Oh Before i forget u need to use this combinations with baffle speakers.This is due to the lack of bass Punch that is link to class A amps. 2. Going to class AB u will be thrill by the impact & dynamic presentations. Fantstic performance and brilliant soundstages. 3. Fix it to your home-theatre well U be glued to it. This F1 pre. is something special . Look at the circuits again and compare it with Aleph P.
I have run this F1 pre. with line purifier , line receiver, Class A Mosfet, Class A JLH , Class AB bias to 300ma
Speakers: JBL, JMlabs , Mission , Goodsman, B & O.
CD player: Rotel fully modified. ( will change the trans. to give more current.)
Let me know when u have set it up. To see how it perform.
bye for now . Music time again.
jh6you said:Thanks lot for your kind details and advices . . .
Enjoy the music!
jh
You are most welcome
Nice board amp.pixs two currently in use for 2 months now.
- First Watt Preamp?
