12 band what?
I was just offering a dirty solution for Mark, but after seeing the response graph for his woofer....yeah it does break up bad & the two in combo will really be all over the map.
Yes you are right , I see...the resolution is not precise enough to fix this "problem". Best to fix it on the Xover end.....as in get it right rather than putting a band-aid on it.
Using a 12 band can be used for mild compensations, but this combo just won't work right & I do believe you all have nailed down a better choice for his first build.
_____________________________________Rick............
