Modules and chassis received!
Everything in good condition because of the very good packaging by LC
One of the aluminum corner guards was dent during travel doing it's job very wel by protecting the precious cargo, wel done!
The casework is stunning, very high grade and has an impeccable finish!
The modules also look very professional and high quality, can't wait to start building...
Is there a list with preferred materials (BOM) available for assembling everything toghether with two Hypex SMPS1200A400 power supplies (like: power switch, (RCA / speaker) terminals, mica insulators, etc..)?
Thanks for creating this peace of art LC!
Regards, Edionysus.
Regards, Edionysus.
Hi Paul
Glad that the package arrived undamaged and Al protective corners did their job properly.
Well the holes are made in standard sizes to fit RCA chinch, WBT or similar speakers terminals, 230 mains connector and small size mains power switch.
First One modules and SMPS1200 fit exactly, bolts were added in the package. 2 mm front plate green LED-s also included in the package.
All these parts can be ordered by Farnell or to buy at your local electronic shop and are compatible with parts from many different producers, that's why I didn't specify any of them particulary.
Looking forward to see your built.
Best regards, L.C.
Best regards, L.C.
Anyone interested First One V 1.1. premium made amplifier
That FO board looks different to mine... Is this improved version?
Mark.
Mark.
No, you have V 1.2 version, this one is V 1.1 last year's model.
Hi tubo
Not necessarily, but some sort of passive attenuation would be recommended between the two.
Serial 2,2 k fixed resistor with shunt 10 k/log potentiometer to GND is a great solution for volume regulation, tested.
Draw the sch to see if you know what I mean.
Regards, L.C.
Regards, L.C.
For much more on cables and grounding and shielding, see these Rane Notes:
Thanks Kevin
HiHey LC can that chassis hold four modules for a fully balanced setup? Can I get away with two of Bruno's SMPS IE each SMPS drives two modules? Or am I basically setting fire to money... LOL
I plan to pair this with an Emotiva XMC-1 that has fully differential outs on the mains L/R so I figured it might as well take advantage of that and have a truly differential signal path from the converter to speaker level.
Here is an AP report on that processor if interested but requires a forum account.
XMC-1 Audio Precision Test Data | The Emotiva Lounge
C1 chassis is 70 mm high and its power dissipation is calculated for two First One modules only, but if it would be higher ie. 120 mm than four modules could be installed without problem. In this case SMPS1200A180 is recommended and the output power would easily reach 500 W/4 Ohm.
Any fully differential preamp could be used to drive balanced First One amp. Personally I tested it with Benchmark DAC2 HGC and it worked perfectly.
Regards, L.C.
If you're also building preamps like the Relaixed I'm curious if your interesting is bring in and testing the Bent Audio Tap transformer based (Slagleformers IE Dave Slagle transformer volume attenuators) preamp with your amp.
BentAudio.com :: TAP
Yes I'm interested, any suggestions?
I just receive what i guess is the First One "First One" in Mexico, Thanks.
Olé
BYRTT, fluid, hose4, thanks guys for your input, appreciated a lot.
Glad appreciated, and thanks mean a lot.
Operation on USA power
The specs for the SMPS1200 indicate that the output voltage is proportional to the mains voltage. Since our mains voltage is typically 110V this means that the SMPS1200A400 will output closer to 30V rather than 63V. I assume that we should use the SMPS1200A700 instead? Independent of the full power limitations, what is the minimum supply voltage that the First One can tolerate?
thanks
thanks
- Vendor's Bazaar
- First One - mosFET amplifier module
