Fake or bad caps....
I bought 8 pieces ELNA FOR AUDIO 10000uf 63v from AUDIOPHONICS to use them in my FO and the measurements showed about 8400 uf.After sales services told me that tolerance is 20% so these caps are OK.But i have never seen in my life before branded product such as ELNA for audio to have such low measurements.They usually have at least 5-10 percent more.I have 7pcs 10 yo ELNA caps and they have 11000uf or more. I am very disappointed and of course I will not use them.Of course they refused my review that's why I'm publishing it here.
New FO modules to be launched in 2018
FO modules v1.6 in final phase of preparation, schematic locked, measurements done. PCB layout on my LCD screen so it looks we could still manage them to be dated with 2018 mark.
FO module v1.6 is unconditionally stable and has been thoroughly sound tested at each step of development with two slightly different amplifiers, one having previous - another current variant, so always better sample proceeded to the next level. Time consuming process gave amazing result, we think. Stay tuned.
Pic showing 500 kHz square wave signal at 20 Vpp on 8 Ohm load.
All measurements and listening sessions done with large modules. No worries, medium will share same topology only one pair of output mosfets. Experienced tons of amps in our system, all kind of brands and profiles, without any doubt or exaggeration I can say FO will be fearless giant killer.
Interested... still have to built my L project but wouldn't mind sizing down... .
Any ideas on price setting for the new modules?
And, LC, somewhere you mentioned you where considering encapsulating the modules in resin... . will you stick to that plan?
And while we're at it... I'd be interested in your experiences with the metrum Pavanne compared to the other dacs your using... .
Rob
Rob
Don't need to, First One L will be produced too.
Same price range as they were, so prices set in the first post of this theme are valid.
Most probably only parts of it, not complete module.
Rob
We use Adagio by Metrum, of course slightly modified, in our main system. I like it is true dual mono DAC, L/R channel's GND are isolated. S/N ratio, feed-forward correction and dynamics are state of the art.
Cheers
Entry level First One module, which is the smallest in the new modules family, has size 80 x 50 mm and could be powered with variety of PSU voltages, meaning power ratings from 50 to 150 W on 8 ohm speakers. Less power is to my opinion reserved for chip amps, therefore no interest of mine. I'm sure you'll be enthusiastic using our smallest module which will find place in many active powered speakers and multi-channel home theater power amps.
v1.6 modules
What is the timeline for the new v1.6 modules availability?
Also, Metrum Adagio is under quite a competition over there. Care to share the differences between Adagio and MSB Select/Reference products you have over there?
In 2018 we had a lot of supporting equipment for our R&D purposes like Grande Utopia Focal loudspeakers, Select and Reference MSB DAC, Adagio Metrum DAC, Siegfried Reference monoblock and preamplifier VTL, Reference 10 preamplifier Audio Research and many many more. The aim of having them for comparisons was to be at least on the same SQ level like the ones mentioned.
Over the weekend we had official launch accompanied with presentation of our new First One 600 power amplifier based on v1.6 modules. 8 power devices per channel generously gives 600 W on 4 Ohm load, easly 1200 W on 2 Ohm. The sound through Mini One speakers was appealing, detailed, realistic attributes kind, we enjoyed together with lots of visitors.
Wow! Looks very cool with the Faraday cage for power supply. Would love to see more pictures of the amp.
Btw, what is the power dissipation of new v1.6 modules with 8 devices? You have some big heatsinks.
This one is intended for PA use?
Have a problem adjusting The L moduls. 2 x 85 VDC. IT get All to hot with just 100 Mv. T 1 to Tp2 and current from 230 Vac is more Then 1.6 A for One Channel. Advise please.
Problem with a Bulky Nippon Chemicon I presume.
- Vendor's Bazaar
- First One - mosFET amplifier module
