Hi Tibi,
I just amended my original order to "mounted and tested x 1 unit"
I noticed i fell from no 35 position to no 90 ?
Regards Rob
Hi Rob,
This morning I found few lines deleted ...
I have added missing lines form a back-up copy.
Anyhow, line position is not important.
Thank you !
Tibi
I don't need the CD mechanism I have two in the shed. Is it possible to stick to my original intent to purchase boards and selected components only?
Thanks Bill
Shure. Any option is accepted.
Tibi
Hi Tibi,
Pls change my order to 1 x Shiga ready mounted and tested. Thanks.
Done with thanks !
Tibi
Add two lines with your name, one for Full Kit and one for SFP101N-16P
Tibi
Hi Tibi,
I cannot see the changes for me in the Google Doc. So I changed it by myself. Please help to check if they are correct! Sorry for that.
ccliu
Hi Tibi,
ccliu
Yes, is correct.
Thank you !
Tibi
kit or ?
Hi Tibi,
I am mixed up a bit. I did not find in the bom the display, neither in the complete kit nor in the fully assembled unit. Is it part of these options?
I found an ir receiver, but I read the remote was not included, what are the options then?
Is TVA applicable for those outside the Euro countries?
THank you,
Hi Tibi,
THank you,
Hi Tibi,
THank you,
See line 103 https://docs.google.com/spreadsheet/ccc?key=0AuQF0EAtUutedEhBYW9hSklhOEVmSERodi1xSldyUUE#gid=0
and yes, display is part of all options unless you choose to not use one.
TVA is applicable for all countries.
Tibi
In this tread have been discussed and tested several puck/clamp models or concepts.
I have reattached one presented by Peter Daniel, which IHO is one of the best.
Tibi
What's the best material for construction?
Is there anyone out there who would consider making a bunch of these for those interested?
3. Shiga Ready Mounted and Tested is an individual PCB with all components mounted - SMD and leaded components.
In that particular case you like to have a partially mounted Shiga Ready Mounted and Tested, you need to mail me this option. The price will be same (169euro) and you´ll will receive THT components as well, but not mounted.
Tibi
Okay, but I'm a little confused. Isn't the Ready Mounted and Tested the audio PCB, the two power supply PCBs, plus the display and interface PCB?
I've changed my request. Now two lines. One Ready Mounted and Tested, the second a Full Kit with all SMDs installed.
Tibi
Tibi, thank you for clarifying a few things here.
I went back in the thread to have answers on the remote control.
I found out that an universal type should do, but will the original EZ-31 boombox remote control be compatible with your design?
Not sure, because I think you have added very interesting features the EZ-31 don't have.
The bom also includes the option of better quality parts. Are these available?
Thank you again
I got this information from ones of Erik posts.
Thinking of it later, I realised this could do for the first Shigaclone project and may not apply with your design.
I would appreciate that you or Erik comment on this.
Thanks again
Ok, let me clarify things even further.
For and ONLY diyaudio members we are offering
DIY Shiga KIT - 40.45euro - TVA included
This include PCB; CD mechanic SFP101N-16P; chipset LA9242M, LC78601RE, LA6541, transistor set 2SA608NF, 2SB764E, 2SA1342; custom multiplexed LCD.
Plase also note that you may order any of this parts in any quantity you need. Also note that you need to be registered on the list before 15.July.
This product will not be available via vicol-audio webshop and all the sale will be done trough diyaudio forum - you contact me and I´l bill you via paypal.
Following two products are commercial and will be available on Vicol-Audio webshop starting with 1st August.
The stock is limited to 100 pcs for FULL Shiga KIT and Shiga ready mounted and tested.
You may reserve one of these products registering on the same list before 15.July
FULL Shiga KIT - 99euro - TVA included
This include all components to build Shigaclone.
You will receive PCB boards, all THT and SMD components, CD mechanic, LCD display and connectors.
That means all components except CD Puck, trafo and remote which are not included.
Shiga ready mounted and tested - 169euro - TVA included
This include all PCB boards populated with components (power supply, main board, display board) , CD mechanic and trafo.
On 1st August we will open webshop for 100 Shigaclone mounted and tested. CD Puck and remote not included.
You may also order FULL Shiga KIT with all SMD mounted, but the price is also 169euro.
Hope this will clarify things a bit and answer to your questions.
Tibi
Tibi
about Vicol-Audio Shiga
What you should know about Vicol-Audio Shiga product.
Vicol-Audio Shiga product is an identical copy of Shigaraki, respectively JVC RC-EZ31 in terms of schematic and active components.
We have sourced exactly the same mechanism
SFP101N-16P
We have sourced exactly the same active components
LA9242M; LC78601RE; LA6541
2SA608NF; 2SB764E; 2SA1342
We have designed and produced a slightly bigger equivalent LCD display. Original one is no more available nor any equivalent one.
LC78601RE is driving a 2 digit multiplexed matrix LCD display. This is not a standard multiplexed LCD as used in multimeter's or other equipments, so we had to made a custom one.
The PCB was completely redesigned using two layer board. This allow better layout, routing and usage of a greater component variety.
Instead original SMD 0805 components we choose to use 1206, offering a slightly better thermal stability.
As the Vicol-Audio Shiga is identical to JVC RC-EZ31 and use same DSP chip LC78601RE, same remote - used by JVC RC-EZ31 - will work perfectly.
Another change you´ll notice is that almost all electrolytic capacitors have been changed to organic polymer and tantalum.
In the last month we have extensively tested different power supply configurations for Shiga. We have powered each chip from separate low noise regulators, or each chip section from separate +5V sources. In some cases, powering different chip sections from separate low noise sources leaded to complete malfunction of Shiga, or highly degraded sound.
Our conclusion is that the original configuration is the best.
The final Vicol-Audio Shiga product will have only one power supply board, as in the original one.
Also during prototype tests we have found several schematic and PCB errors in our design. These have been corrected.
Tibi
SFP101N-16P
Tibi
- Digital Source
- Finally, an affordable CD Transport: the Shigaclone story
