Finally, an affordable CD Transport: the Shigaclone story
Administrator
Joined 2004
Here is my listening room and lab space. (Dedicated basement room)
Here is the original before the malfunction that ruined the controller board.
Here is the ShigaClone "Clone" with the same mechanism as the first and a new display and controller board - all mounted on the aluminum baseplate that will be the bottom of the transport chassis when done.
This thing sounds progressively better as it warms up.
For those you who want to completely separate the power supply for the controller and the mechanism/processor board all you need to do is change the relay to a dpst, add another bridge rectifier and cap and use that to feed the LM7808 which powers the mechanism.
I have changed just a few components in the mechanism board.
I deleted the common mode choke. I also changed all of the 10uF caps on the board to stand BG, and a couple of 1000uF caps to 47uF standard black gates as well.
I bought some nice Chinese made momentary push button switches to replace the onboard push buttons and will get a momentary NC pushbotton for loading. (simulate door closed/open/closed to initiate a new toc read.)
Nice work Kevin - bet it sounds great! Mine is still running on a mouse mat!!! Bet it sounds good on that thick base with those spacers connecting the transport solidly to it.
Managed to get the sound quality back that I was missing from my upgrades. As suspected, replacing the crystal back to the original ZTT 16.93MX instantly opened out the sound, bought solidity to the bass, and that wonderful near-analogue sense of openess again, and crystal clear top end. In short - I'm VERY pleased again - I was beginning to think I'd imagined the superb sound this mechanism was/is capable of! I downloaded the datasheet for the ZTT 'ceramic resonator' and it has built-in load capacitance, which MAY be why - to me at least - it sounds better. I think perhaps my Citizen crystal needed that recommended (by Sanyo in their datasheet for the LC78601RE controller chip which is located on the JVC circuit board) pair of 8pF caps. Peter managed without, but to me the sound felt 'sat upon', lifeless and unable to blossom. I guess it will vary from transport to transport, crystal to crystal. For me the Citizen didn't work well.
So.... to sum up my experiences thus far, KEEP the 0.1uF / 50v cap (C906) and X901. Changing the PSU caps detailed by Okapi in his detailed PDF is definately an improvement however, along with the new PSU - hope this is all of help to someone!
- John
  • ceramic-resonator-ztt.pdf
Administrator
Joined 2004
Hi Johnm,
Up until now I have mainly focused so far on getting the micro-controller board issues sorted out, and now that I have completed that I can proceed to the next phase and that is evaluating what if any further changes I can/should make to the mechanism and board.
So far I have changed the resonator to the Citizen Crystal Peter recommended which I thought made for a very noticeable improvement. The stock resonator made things sound a bit grainy to put it nicely.. :D This was done in isolation to any other changes - it was the first thing I did IIRC.
I also have removed the common mode choke and replaced a few capacitors here and there. One of these is the supply bypass for the dsp chip LC78629, and the others are used to determine various tc in the ASP (LA9241). I did notice some improvement with the replacement of these various caps. I have not replaced the tracking servo tc cap which in my unit appears to be 0.33uF - some experimentation is warranted here. I need to identify the analogs to the other caps changed in the RCEZ31, but I am probably on my own here. I do have all of the required data sheets so this should help.
Due to the fact that I am using an outboard micro-controller the PSU got rather elaborate compared to what is required for the RCEZ31 version, due to space constraints I elected to go with a single bridge (individual high speed Schottky rectifiers) and a single low ESR cap. It is possible that further improvement is possible with a separate supply for the mechanism as long as it remains under the control of the uP power control circuit. I will report that there was a pretty substantial reduction in noise and ground bounce visible on the spdif output after changing to this supply.
In terms of the sonics I can't compare to the RCEZ31 based version - not having heard that, that said I suspect they are quite similar given the similar construction and related chipset.
Cold it is not very impressive, sounds about like you would expect for about $5 worth of electronics and mechanism, and lest you think I exaggerate bear in mind what the assembled boom box costs with all profits and shipping/warehousing expense added.
As it warms up the sound seems to evolve, it always retains a certain polite understatement, but the sound blooms, by this I mean the sound stage opens up, depth and width increase greatly, you become aware of the fact that you are hearing a surprising level of background detail, highs are clean and very extended, and the music has a nice flow to it. Bass is very good even when cold. On really well recorded CDs there is an almost analog like quality to the sound.
I recently built myself a new dac, and I am sure a lot of what I hear is the dac's ability to resolve very subtle detail. It is pleasing though that this inexpensive mechanism complements it so well.
All of the above and I am having fun too. I doubt I could have bought any cd player on eBay for for what I have spent so far that would do the job as well..
Administrator
Joined 2004
I spent about an hour or so listening to it this morning, have to say that while it does a lot of things right there is a certain mechanical quality to the sound that never quite goes away.. Could be nothing more than the break in of the few BG caps I have so far installed, or it could be an indication that more work is required.
I do plan to add a considerable amount of additional mass on either side of the mechanism. This will either be aluminum or brass bar stock - basically whatever I can get my hands on.
One thing I can say is it is working quite predictably, no odd quirks at all.
Now it is just a matter of finding the level of refinement I seek.
I purchased a bunch of 75 ohm bnc from Digikey and plan to replace the current 50 ohm bnc on the clone as well as on the dac.. I will probably work on improving the supply decoupling and upgrade the remainder of decoupling caps on the mechanism board. (Yet another order to Michael Percy.. :) )
Administrator
Joined 2004
I think later this afternoon I will remove that ferrite on the ac power leads to the transformer. Not sure why I didn't do it before soldering the iec connector to its leads, but it was done very early in the process.
I'm debating whether or not to get another transformer as this one runs near stone cold after several hours - as does the rest of my supply in fact. This transformer is also mechanically very quiet - an important consideration in my room. Compared to the original boom box this supply is quite lightly loaded.
Can anyone say for sure that using another (larger) EI transformer makes any audible difference?
John's comments on the crystal are interesting, and like him I still have the original around.. (just seemed grainy as I commented before.) I also have a completely stock mechanism I am keeping as a spare so comparisons are possible.
I am also going to work on improving decoupling in the supply and on the mechanism board as well.
FWIW it is worth I have heard far worse from far more expensive and respected kit. My system is highly resolving and unforgiving, and yet it still manages to sound pretty good - just not quite where I want it to be yet. The fact that it works at all, and as well as it does is a small miracle given what I did to the last one.. ;)
I can say that I hear difference between PS configurations . I've tryed at least 5 different transformers , and the big differences are between : 4 diodes - 2 diodes . Toroidal and typical ( cant remember the name ) .
I would not go myself for more than 50VA . Also different transformer into theyr category seems to produce audible consequences .
Anyway I am indecided between a little 12 + 12 toroidal ( that runs pretty fresh ) , and a something bigger " tytpical " transformer . sorry again for the lack of the right term to use . My taste tends to the 2 diodes configuration .
I used also shottky and like them .
Not last -for me - worked greatly to disconnect all the rest of the circuitry of the boom box from the transport .
I have to say I am still of the opinion that my unit sounded better when it was stock, being truthful. It's not an easy thing to admit because I've put quite a bit of work into it, and money that I don't have at present.
When stock I really hadn't heard anything quite as good as this for a LONG while.
I'm hoping it still is the infamous Black Gate burn in process. It's only really been a few days, and it can take 400+ hours I've heard (worse case) - eeeeek!
I think I should have installed the PS as Peter said, then got used to that sound, THEN have seen if the upgraded crystal and 0.1uF cap made a positive difference... perhaps the reason I didn't like the sound with the upgraded items was simply due to the Black Gates burning in. Too many variables at once :xeye:
Anyway going to continue simple listening to music on it and see what happens.
As a matter of fact , I am just managing with PS , didnt changed anything yet( well the inductor is not there ) , and it works very good for me . I may add , transport noise ( motors ) decreased a little with use .
And I like the output SPDIF divider with 291 and 100 ohm and 75ohm cable . It is very quiet on the background , and with good recording I can hear good placement of the instruments they seemed to me more confused either without divider than with 75 and 75 .
I already mentioned it few times, and can't stress it enough: don't change anything on a main board exactly as I did; that it worked for me, does not neccessarily mean it will work for somebody else, in a different system and different sonic preferrences. You need to find your sound that pleases you;)
If I can suggest a an upgrade path, I would do it in that particular order:
1) outpboard supply: check different transformer types and power rating, diode types and bridge configurations
2) the regulator type, most likely LM7808 is a proven choice, but experiment with caps before and after regulator.
3) check the crystal, I only use that particular Citizen type, because nothing else was available form DigiKey. It also worked better than stock oscillator and one other crystal I bought locally.
4) check the first two caps on main board (470uF and 220uF). I removed the bigger one completely as it's in parallel with main cap after the regulator, 220uF was replaced by BG N 47uF only because I like "image density" of BG N caps, but your taste may be different.
Only then, change any other components on the main board, I didn't do much, only the caps that are directly on supply rails and because my main bypass is BG N, I changed other caps to BG N as well (but smaller values) and removed SMD caps. And do it one by one in steps, so you can monitor the differences each component change brings.
There is one other cap worth experimenting with (C906) but do this as the last mod.
One other thing with regards to output resistors, while I had good results with 75/75R at the output, as it increased the presence factor and improved air, especially with BG FK I was using initially and which sounded a bit mellow, after I switched to F caps (not available any longer) I have pretty good results now with resistors closer to properly calculated values (300/100R) and I'm still experimenting in that area, but as Stefano said, with calculated values it seems like imaging is more solid and less "confused".
Lastly but very important, is the mechanical construction of supporting frame. In my experience, it is probably 30% of overall sound, and it makes or brakes the sound of the unit. Some people reported good results with mechanism simply placed on some foam, but I tried and sounded rather uninteresting. A good starting point would be a wooden platform and two brass standoffs and from here you may move towards more advanced constructions.
Reactions: 1 user
Peter, given Johnm's findings, can you just confirm that of the mods listed by Okapi, If I were to remove the items he has removed, and leave the rest as standard, it will still work ?
http://tim.cheapo.cc/images/CD player mods.pdf
If that is the case, why were they there in the first place ?
In relation to the 75/75 resistors on the dig out. I tried this and got a lot of hum. Can I just check I got the wiring right. One resisitor goes from the + side of the dig out to Phono and the other intersects and goes to ground, at one (transport) end only ?
http://www.diyaudio.com/forums/attachment.php?s=&postid=1482822&stamp=1208083104
Finally, can you confirm you got payment from PayPal.
By my point of view the board on the EZ31 is made particularly to accept a Toslink optical transmitter . There is the output , the 5 volt , and ground . So when connectin the SPDIF just be sure to not touch the 5V ( central pin ) . As for the exact way of connectin the divider look here
post #317
The mods listed by Okapi is what I'm using now, so it certainly works. And you can do them too, but go step by step, monitoring each change, so if something does not work to your likening, you will know what it is and you can revert to the original. If you change everything all at once, and suddenly you loose that "bloom" it would be much harder to figure out which particular change is responsible for that.
You package was shipped last Friday, if you find that some parts are not needed, you can send them back for a refund (providing jackets are perfect condition and pins at least 5mm long).
Thanks Peter. Any comments on :-
"If I were to remove the items he has removed, and leave the rest as standard, it will still work ?"
And
"In relation to the 75/75 resistors on the dig out. I tried this and got a lot of hum. Can I just check I got the wiring right. One resisitor goes from the + side of the dig out to Phono and the other intersects and goes to ground, at one (transport) end only ? OR BOTH ?"
And
As I said, the items he removed, is exactly what I did and it works fine for me. The rest is standard for me too.
There is no + side of digital signal marked on a board. There is +5V which you dont' use, DOUT which is digital signal and GND.
Series resistor connects to DOUT, shunt resistor connects between series resistor output and GND, as on schematic posted by Stefano.
I guess that line might have brought some confusion, I should rather say: don't do everything exactly as I did; different parts substitution could work better in other setups, so spend some time experimenting and choosing parts that work best for YOU.
Joined 2005
After going back a few posts to where the jumper is required on the stock PS board to replace the switch on the AC cord input, the system (guts of EZ32) is alive.
The EZ32 has a 7808 regulator on it, so will work for now while I work on Kevin's mods to get rid of the audio board. Waiting for some of those $3 25VCT transformers from Parts Express to arrive while laying out a new board.
Took the small 3 pin header off the corner of the audio board and put it in the holes where the DOUT is located on this unit, so I can play with the SPDIF loading without having to touch the board, but it sounds nice for now with 390/100 ohms, feeding one of Peter's NOS DAC's.
Now the real fun begins.
Thanks to all for help in this thread.
Craig
Administrator
Joined 2004
RCEZ32 Clone Update
Happy to report that removing the ferrite on the ac power leads to the stock transformer effected a pretty big improvement. The mechanical sound quality I complained about in my last post is mostly gone.
I tried several other EI transformers and noted no particular sonic advantage while listening so I stuck the stock transformer back in my transport. It fits and some of the bigger ones really do not.
Finally I added a couple of small 33uF/63V Nichicon VZ series caps at the output of the 8V supply. I noted some improvement in the smoothness of the highs, and a slight improvement in overall imaging. I did not use BG caps in my supplies so I cannot indicate whether or not this would result in an improvement or not.
I am now also able to use the remote control.
For whatever reason this thing certainly is revealing, far better in some respects perhaps than any cd player I have owned to this point. I am sometimes amazed at what it does for multi-track vocals, it resolves rather well.
