Hi all, I have a pending issue to address.
Recently I diy a tube preamp wif a matching tube rectifier power supply. I used this combo on my existing old Sansui amp.
It seems like the amp relay un-triggered(protection led blinking) as it sensed dc on the preamp pre-out stage.
Hence do I have any solution to rectify this issue? Meaning that I able to block any dc from pre-out stage of the tubes entering the power amp stage?
Tks for the feedback.
Schematic? Is this a published design or your own design? Is there any anything in the design that addresses AC coupling of the output, such as a capacitor or a servo?
Yes it a published circuit diagram of the M7.
Unaware of uploading the diagram though.
Has the output socket, on the preamp, got zero volts DC on it?
If not, it's a bad output coupling capacitor.
If the circuit is otherwise sound, there may be a turn-on transient from the preamp that the amplifier sees.
I've always added muting at the outputs of tube preamps, in the form of a normally closed relay that shorts
the outputs to ground. It's run by a 555 timer that enables the output after 30 seconds (or more).
Another option instead of the above would be significantly reducing the size of the output coupling capacitors.
Difficult to tell from a fuzzy picture, but it looks like a 3.3uF output cap with a 1M ground leak resistor. This could put out a significant voltage for quite a lot of seconds after switching on, even with the slow start of a valve rectifier. Change the resistor to 100k and see if that fixes it.
Yes, or decrease the cap size by a similar factor, which may also improve the sound.
What's the amplifier's input impedance?
Fyi amplifier input impedance is 50kohm.
- Tubes / Valves
- Filtering of DC volts?
