would a high power loc degrade quality? i heard that only the expensive ones dont.
im trying to keep this as cheap as possible too.
i think im going to rewire the loc's from right behind the hu and run rca's to the amp instead of running the speaker wires to the amp where the loc are.
then maybe ground them to the hu
Your current LOC's may be the issue with all the noise. I would consider THESE. I mean short of buying a new head-unit that has at least 2-5v pre-outs to drive the signal to your amps the stinger converters would be cheaper. Yes I would run that at the radio with no speaker connected. Just radio to LOC and rca to amp.would a high power loc degrade quality? i heard that only the expensive ones dont.
the thing is, the amp inputs are not adjustable. it is rated for 0.775v.
my calculations(if they are right) sow that right now im and just over 1v, so that may be a bit of the problem, but def not all of it. i have a pair of 10k stereo pots coming to see if thats the case.
im using both front and rears, 2 loc's.
it is the sure 4x100w t-amp board
here is the pe page
Sure 4x100W @ 4 Ohm TK2050 Class-D Audio Amplifier Board
here is pdf info and schematics
http://www.parts-express.com/pdf/320-302m.pdf
here is the pe page
In post #3 it say's you have a direct ground for this amp running to your battery correct? If so have to tried grounding less then 18" right to the body? It would be easy to do.
that was just for troubleshooting purposes. its at a factory ground point about 2.5' away
When you say "Factory" can be more specific? or show a pic?that was just for troubleshooting purposes. its at a factory ground point about 2.5' away
well i re-did the front loc from right at the back of the head unit, hoping to get less noise but its still there. im gonna try to reground the amp to the seat bolt tonight, if i can find time. havent bothered with the pots yet. dont think they will change the noise at all.
if i have time i might try to make a choke-capacitor filter out of some old computer psu parts. dont think i have a large enough cap handy tho.
OK, i think this hu has active balanced outputs which isn't a huge deal, but if i use a different source with the same result doesn't that mean it isn't the loc or hu?
I'm going to try and make a filter for the power line. Will an RC filter do? Or an LC? Which should i try?
well i ended up getting a P.A.C. SOEM-4 to solve my problem. i guess the hu was either balanced/differential, or 4 wire common ground. i used my vag-com and programmed it for low level output and it sounded much better as far as the quality, but the whine and buzz were worse when the car was on. so i put the loc in there to convert to a normal single ended signal. now i have very very little buzz from the rear speakers only, and very very faint whine. you cant hear the buzz with the car running, and you can only hear the whine if the volume is all the way down. first notch up and its drowned out. im pretty sure both issues are from my extra cheap rca's i used for my rear input.
- General Interest
- Car Audio
- filter for sure t-amp in car?
