Hello all,
My apologies, as I had a hip fracture a few months ago and have been unable to resume troubleshooting until now...
thanks - yes, I've cleaned the jacks and pots.... of course, sometimes replacing a switch, jack, or pot is the only way to fix some noise.
I've decided to record a few samples to demonstrate the sound.
The Volume was set on 1.5, and all other controls were on 12 o'clock, with the exception of the chorus (bypassed), in which the rate was at 10 and the depth was on 0, per the schematic guide. The Delta Comp compression was bypassed (although the distorted sound is identical with compression on).
In the attached zip file, I've included 2 mp3 files. There's no password on the files.
Thanks for any help...
In the meantime, in the next few days, I will begin posting the testpoint measurements once again, starting from the first, recommendations in the schematic.
Kind Regards
Kind Regards
Hello all and thanks for your kind msgs,
Attached are my scope shots of Test Points 1 through 10.
Scope settings were as follows:
Photo 1 (TP-1) .5V/Div
Photo 2 (TP-2) .5V/Div
Photo 3 (TP-3) .5V/Div
Photo 4 (TP-4) .5V/Div
Photo 5 (TP-4) .1V/Div
Photo 6 (TP-5) .5V/Div
Photo 7 (TP-6) [Delta compressor - 'off'] 2V/Div
Photo 8 (TP-6) [Delta compressor - 'on'] 2V/Div
Photo 9 (TP-7) [Delta compressor - 'on'] .5V/Div
Photo 10 (TP-7) [Delta compressor - 'off'] 1V/Div
This is the test point section for the pre-amp.
In the next week, I will post the remainder (pwr amp section).
Thanks for any leads or pointers.
