Can you show the example?
Sure, there is a worked example with more detail than I could show here, in part 4 Nodal_Analysis that is repeated in the next section (Mesh Analysis).
Compare the matrices.
Best wishes
David
I know order and degree but what is the grade of a linear DE?
I think he means order, but have never seen the term "grade" used wrt DEs.
I think he means order...
Probably, but I can't quite make sense of his answer and I want to check whether the answer actually makes sense before I spend too much time.
And Waly sometimes finds obscure treasures of information.
Best wishes
David
Did the examples check?
I can't say anything to Waly's post. That's beyond my horizon.
But to the addmittance/impedance matrices:
One can interpret them in a graph theoretic way with loop-matrices and cut-matrices. And they are not independent.
For details, I had to reread it by myself.
W. K. Chen: Applied Graph Theory
Vlach: Computational methods for circuit analysis
Pen-Min Lin: Symbolic Network Analysis
By the way there exist graph theoretic interpretations for determinants.
Then in nodal analysis I=G*U the I are independent current sources and the V are node voltages.
In mesh analysis V=Z*I the I are loop currents and the V are independent voltage sources.
So the V and I are not the same in both methods.
I think about the difference between the GFT and Tians method.
And if it is possible to 'realize' the GFT in a DPI/SFG way.
Or has this already done somebody?
Josef
Josef
...But to the addmittance/impedance matrices:
Correct, they are not simple inverses but they are not independent.
That was point of my earlier post.
...But they both provide the correct answer so there must be some deeper structure that I don't quite understand.
Thanks for the additional references. I add them to your earlier WK Chen reference, which I did find a copy.For details, I had to reread it by myself...
What are they?By the way there exist graph theoretic interpretations for determinants.
Then in nodal analysis I=G*U the I are independent current sources and the V are....
In mesh analysis V=Z*I the I are loop currents and the V are...
That is an excellent explanation.
I also think about this but have not done it myself nor have I been able to find anyone who already has.
I have already searched this forum but most of the posts about GFT seem to be only my own, or in reply.
So I need to search more widely.
Best wishes
David
E.g. from W.K. Chen Applied Graph TheoryWhat are they?By the way there exist graph theoretic interpretations for determinants.
Theorem 2.28: The determinant of the node-addmittance matrix Yn of an RLC network is given by det(Yn) = SUM( tree admittance procduct ).
Simple example with an R-network with admittances.
Code:
1-----y1------2
y4 --y5-- y2
0-----y3------3
y1.y2.y3, y1.y2.y4, y1.y3.y4, y1.y3.y5, y1.y4.y5, y2.y3.y4, y2.y3.y5, y2.y4.y5
Incidence matrix Yn of the network is:
{{y1+y4+y5, -y1 , -y5},
{ -y1 , y1+y2 , -y2 },
{ -y5 , -y2 , y2+y3+y5}}
The determinant is:
Det(Yn) = y1.y2.y3 + y1.y2.y4 + y1.y3.y4 + y2.y3.y4 + y1.y3.y5 + y2.y3.y5 + y1.y4.y5 + y2.y4.y5
The terms in the determinant match with the trees.
There are enumerations over trees for directed and undirected graphs
and a lot of more stuff.
Best wishes
Josef
Thank you, it looks like I need to read the book to understand the context better.
Best wishes
David
Mr. Zan,
- Are you able to write the linear differential equation that, together with the boundary condition (essentially defined by the independent sources) completely and uniquely characterizes the time evolution of an arbitrary electrical circuit?
- Do you understand the concept of phase space and the phase space method for analyzing the solution of a dynamic system (that is, solving the time dependent differential equation)? A particular solution is a time parametrized trajectory in the phase space, can you visualize in the phase space all possible solutions (each depending on a set of boundary conditions) of a certain linear differential equation?
- Do you understand the isomorphism between the space of linear operators L(U, V) with dim(U)=m dim(V)=n and the space of m X n matrices?
- For the particular case of a linear differential operator and boundary conditions, can you calculate the coefficients and write the equivalent n X n matrix? Are you surprised by the result?
If the answer to any of the above is "no" then you need a crash course in vector space theory and the connection to linear algebra. I wish these things were more intuitive, unfortunately they are not. I can't further help on a public forum, I already went above and beyond.
Welcome to the club
Linear algebra is an efficient way of handling a group of related equations, and is the basis
of SPICE and MATLAB (which stands for MATrix LABoratory).
I know my limitations, and gave up reading this Thread weeks ago. But I keep coming and I know not why.
Welcome to the club
Jan
You could contribute and share your listening test results.
Haha - you think you or anybody else would be interested?
I am OK with algebra and simultaneous equations. But I never really got my head around matrix stuff...
Jan
Maybe, I think it sounds a little to clinically analytic with a touch of math rock.
what, beyond satisfying intellectual curiosity can we expect
I don't think many "visualize" beyond 3 dimensions, although some can apparently do a bit of mental manipulation in 4-D
when I occasionally search for "geometric" in control I think I see 2 fundamentally different approaches:
Differential Geometry of the phase space: 2016 | Nonlinear Control: Geometric Approach - TOKYO TECH OCW
and "Algebraic Geometry" of the matrix polynomials: Methods of Algebraic Geometry in Control Theory: Part I - Scalar | Peter Falb | Springer
I haven't been motivated to step up to those - my impression is the differential geometry/phase space is somewhat useful for strongly nonlinear systems
but in Audio its pretty much only PA where we really need gain device strongly nonlinear operation - and then we finesse with bias, complementary stages
handling PA clipping, slew limiting, SOA protection may well benefit from more control theory sophistication than I currently have or see locally
but I suspect there really isn't that much practical simple, discrete analog amplifier circuit improvement likely to come from stepping up
possibly could do more if you want to go digital, MHz DAC driving output Q base' with ADSL Buffers, then you could have scope for sophisticated nonlinear algorithms
Jan
Ironically Jan, they are the same.
The original question was about the interpretation of the determinant of an admittance matrix.
The usual geometric interpretation of a determinant is equivalent to the volume, in the phase space, occupied by all time parametrized trajectories of the equivalent (isomorphic) linear differential operator. I would think (just my guts feeling) this volume could be interpreted as a metric of "circuit complexity".
The Cramer rule just picks one of these trajectories, in fact enforced by the boundary conditions.
Simply nitpicking, as usual.
...think in terms of a Nth grade linear differential equation associated to a circuit...
First can I have an answer to my simple question?
Best wishes
David
what...can we expect?
Also for Jan and Andrew.
I wanted to understand the internal feedback loops in a power amplifier, to optimize performance.
For instance to decide if local feedback was better applied around the VAS, as in a classic "Blameless", or around the OPS and VAS, as Cherry claims, or VAS and IPS, as Bob Cordell has used, or some combination or alternative.
I finally have some nice analysis results for this, subject to the condition that there is no "null loop" path.
I would like to include the null loop effects because that would advance the state of the art.
Tian and Ochoa do not consider the null-loop, Bode and Middlebrook do.
But much of Bode is formulated in terms of matrix determinants that I find difficult to understand intuitively, so I made a query about the interpretation of determinants.
So what I hopefully expect is better optimized power amplifiers, to me that means indisputably inaudible distortion with reduced complexity.
Best wishes
David
- Feedback
