FE167E Bass Reflex w/Ported Stand
Ever since seeing the plans for this speaker years ago, I have wanted to build them on aesthetics alone. I recently acquired some 3/4" 11-ply Baltic Birch and decided to let the chips fly.
I was shocked at the outcome! They extended much lower in the bass region than I expected. They have the signature Fostex harshness, but overall, a very enjoyable listening experience. These were built for the Master Bedroom but have a temporary home as my primary speaker whilst I build my Markaudio Alpair 12P Pensils.
Only thing left to do is stuff, sand and seal!
They look great! Are you using any baffle-step correction?
IG
No BSC, straight from the Dynaco transformer to the speaker! I am only really noticing a harshness in upper midrange. I am considering the phase plug mod.
Very nice Craigtone! I have a pair of the same drivers in small BR cabs and they love my bottlehead 2A3 amp.
Mario
Thanks! It was a surprisingly complex build ... a LOT of pieces to glue together! I plan on building a set DRD 300B monos this winter. After this build, I am now a firm believer in fullrange drivers!
how many hours on the drivers?
In addition to the "signature" Fostex harshness is the well known roller coaster ride during the break-in period - at least a couple of hundred hours
and yes, the phase plugs are one step towards taming these
Not sure ... I picked them up from Bob Brines used ... IIRC, several hundred hours, so should be well broken-in by now.
I am pretty sure I'll do the phase plug mod even if it reduces a little top end. I can always compensate with a set of T90A's if need be! :p
Yes, those drivers are well used. Phase plugs will put a hole in the response 5-7kHz that reduces sibilance and smooths out female voice. See my review of this.. Phase plugs to nothing with the main cone breakup 3-5kHz nor do they affect the top end.
One thing to note: Your cabinet have no real bass. When modeled, they have an F3 of somewhere around 105Hz. While the cabinet is "tuned" to ~40Hz, it is acting like an aperiodic box. The lack of bass is one reason they sound bright. Cross them over at 150Hz or so to a sub(s).
Bob
craig: while I imagine you'll be spending much more time over the next couple of weeks with the new 12Ps, as Bob says, the FE167 will never shine in the Fostex design - they are capable of digging much deeper than 100 or so, but would need something like an MLTL, such as:
M12-F165
(seen here sporting the FF165WK with some dimensional changes, but IINM very similar to Bob's longstanding design for the FE167E)
or larger volume ported enclosure - this one works fairly well
Where can I find that design bass reflex stand port... thanks, dan
http://www.fostexinternational.com/docs/speaker_components/pdf/recom_enclose/167e_enclrev.pdf
If building these, I'd fill the bottom portion of column with dry sand, lead shot, etc. , and note that their photo shows plywood ;)
But honestly, I think that a well executed MLTL design, such as Bob's referenced earlier in the thread would deliver much better bass, and occupy hardly any additional floorspace, if at all.
^ Those are the plans I used. I filled the bottom of the column with coal slag blasting media.
Disabled Account
Joined 2009
In the last few months two identical sized cabinets of ~ 18 liter have been built. One pair is sealed and the other pair is BR. Extensive modelling showed this to be the optimum size - for the BR add a 1.1 Ohm resistor, for the sealed add a 3 Ohm resistor. Port 59 mm dia, 114 mm long. Wife is pleased with the sealed, I am pleased with the BR. (she has hearing issues - too much group delay muddles the music ) Three small cubes (all sides equal size) of foam tames the whizzer (after trying out cotton wool etc)
