Fake transistors?
Hi
The pictured transistors 2SA1302/2SC3281 arriver yesterday from FUTURLEC eshop.
These were supposed to be MOSPEC brand and I thought that it would be an easy solution and that there isn’t possibly a MOSPEC fake since they can make fakes with TOSHIBA brand which are more expensive to sell them with more profit so there is no point in making a fake MOSPEC.
The problem is that the transistors I received have a logo that is similar to MOSPEC but it is different and also the case is much bigger, it should be (as in the mospec datasheet) TO247 (21,5mm x 15,8) but instead this is a TO264 (26mm x 20mm).
I was wondering is anyone recognizes the logo, can it be of another company?
As you can see the logo resembles the MOSPEC logo but the C looks like an A.
Thank you
Alex
mospec 2sa1302/2sc3281
I did not know Mospec had bought the license to make them.The logo looks misleading but the size is correct (TO 264).With counterfeiting widespread I would think Mospec would have use laser marking instead of cheap silkscreen.I guess the only way is to split open the package and look at the die size.
Re: mospec 2sa1302/2sc3281
Hi
According to the mospec datasheet for these transistors the case should be TO247 as the one in the picture i posted in the first message, toshiba is the one that makes the TO264 (and the fakes too are TO264).
Have you ever seen the mospec logo on a transistor and if so was it like the one on my picture or like the one in the datasheet (which i also have in the lower section of my attached picture in the first post).
Isn't the capacitance high enough, if the waffer was small wouldn't the cap. be less?
Alex
