Fairly fast buffer
The uncommitted inputs are, of course, op-amp style; unity gain is achieved by tying -In to Output, adding a small "base stopper" resistor (100 ohms) if necessary.
Values shown are slightly different than the circuit I breadboarded (solderlessly, I might add, and no I didn't build an oscillator in the process, but that doesn't mean you will have as much success!), as well as the voltage, mainly because higher voltage is more useful, and I don't have the original schematic on hand to copy directly.
Tim
