F6 Amplifier
Joined 2009
Complete, is working. G resistance to change 1K no Self-excited.
Congratulations, may I ask you is the picture from hifidiy.net or your own?
I tried to recognize the board, is it selfmade and you used some Lundahls? For the oscillation didnt you make a fault in the positive and negative transformer connection?
That was the one and only reason I had oscillation.....! :)
Joined 2009
Hi kiven chen,
the phasing is correct I looked at your design on the hifidiy.net.
maybe your 2SK1058 are more susceptible to oscillation...
maybe you should only drive the Semisouth without source resistors as far as I understood Nelsons comments.
for other semiconductors the 0R22 or 0R47 are recommended.... maybe for antioscillation or against running hot ... do not know the right word...thermal break away....:)
The pictures above - that is with excited ? What is picture with 1 k G resistors ?
I mean, MOSFET 2SK1058 (Metal-Oxide-Semiconductor Field-Effect-Transistor) Gate resistance from 47.5 ohms changed to 1K ohms.
Tried it again today,
has come up with a good reason may be the leader,
2sk1058 grid resistance is greater than 68 Ohm is not Self-excited,
on google.com K1058 amplifier Circuit diagram, most used a 220 Ohm,
I don't know if I should put a 220 Ohm, or with a 100 ohm, or other?
Kiven, for gate resistor, use smallest value that still gives stability. In your case above, maybe 100R is ok.
Higher value =maybe more stable= but maybe poorer high frequency response.
Many people use small capacitor between source and gate to ensure stability especially in quasi complementary designs. You can see same in hiraga circuits. Good luck !
