F5T Premium kit GB
sts9fan,
You may be seeing a heatsink on the cascode transistors.
emyeuoi,
Your kit will ship with your transformers, once they are delivered, as we discussed. Richard at Primrose said that the 800/1000VA willbe done at the end of the month and the ohers will be started after that. I can send your kit seperately, but it will be more expensive.
Joined 2010
I don't realize that the trafo smaller then 800/1000VA will be started later.
This mean that likely will be ready by 15/20 june and will be here end of june/beginning of july that is quite far away. You have any idea how much is the cost of the ship if we split the kit?
Regards,
A v3 will need a larger box, so you are looking at medium flat rate box from USPS. Postage is $50+/-. I can ship standard, but it can take up to 3-4 weeks that route. This is why i recommended shipping with the transformers. It greatly reduces your shipping cost. I will do whatever you want. It is possible that the transformers will get done faster, i was just passing on what I know.
Joined 2010
Thanks Buzzforb for the reply and I know that you just passing on what you know... If I understand you are saying that the USPS without transformer will be +/- 50$. But USPS is the fast one? I mean in 1 week I can get here the Kit?
Standard ship is absolutely to avoid in korea!... I already have a bad experience about... no body speak or read english and only international courier can reach the addresses that are not write in korean
