F5 Turbo Builders Thread
With rails of 32 volts, you may get 28 volts of swing, this gives you MAX 50 watts Class A with 100 watt peak. If you bought this amp it would be listed as a 50 watt amp. That is a lot of class A power, but less power than an 80 watt Accuphase class AB. You are lacking rail volts to get higher wattage. I suspect you will not notice any lack of power between the two amps, the class A may even sound more powerful due to better control, etc.
You would have to go to 44 volt rails to get to 100 watts average class A power and your total bias current would need to go up to 2.5 amps. That's a lot of heat for you to get rid of.
Rush
Hi Rush,
Thanks for the information.
In a standard push-pull Class A output stage, the 'bias' swing is like a string cord.
5A bias level is +5A and -5A, looking at/from the output node.
Max Class A output current is either +10A, or -10A.
In the F5T, 'bias' swing is like a string of rubber.
The T output stage has an asymmetrical behavior, due to the added diodes.
Means that 5A quiescent current level, corresponds to more than 10A peak Class A output current.
Aka, one gate opens faster than the other gate closes.
