I learned a lot from mr.PAss and this forum in general so I decided to donate the pcb files to this comunity.
Everyone is free to make the PCB-s as long as there`s my name printed on them and of course, NO financial gain.
Cheers!
Borko.
first PDF file:
Cheers!
Borko.
first PDF file:
bogdan_borko PCB
Borko, drill points and everything!
Have you wired it up and hearing anything yet? I'd rather you weed out any mistakes, before I check schematic. I like this, this is a bit larger than some of the others, may be easier for the Gorilla fisted to wire.
bogdan_borko said:I learned a lot from mr.PAss and this forum in general so I decided to donate the pcb files to this comunity.
Cheers!
Borko.
first PDF file:
Re: bogdan_borko PCB
please - recheck it by your self ...... it's certainly easy enough
( NB - I don't do pcbs , at least not with proggies ; in any way - I'm lousy at that .....)
Re: My F5 from Aleph J chassis
How does the sound compare with the Aleph J?
rubydac said:My completed project of F5 from Aleph J chssis, I mis understood about parallel 2.4 ohm on the positive site so then I use both site of amplifier
Its sound so beautiful but if I need more power , how do I do ?
Rubydac
The pcb is rechecked a number of times and is ok. Don`t worry, it will work! After all you need 10 minutes to recheck it you self.
some details:
R9-R14 = 2W
R3 and R4 = 1W
R23-R26 = 2W
C3 and C4 = 470uF/35-50V
C1 and C2 = 100nF/50V
The Protel schematic is attached:
some details:
R9-R14 = 2W
R3 and R4 = 1W
R23-R26 = 2W
bogdan_borko said:BTW I`d like to hear what mr.PAss thinks of this PCB design of mine?
Thanks in advance.
CHeers.
Borko.
>Old Rooster mode ON<
seems fine
>Old Rooster mode Off<
Here's my latest version -- with compensation on the input (150pF), a place for the resistors to adjust the resistors on the source of one MOSFET and one JFET. I use TO-220's for the feedback resistor as I have plenty in stock:
EUVL said:If you have a low impedance speaker, you need more current rather than voltage. You can of course start paralleling matched output devices (e.g. using 2 pairs of MOSFETs will give maximum power at 4 ohm). But paralleling MOSFETs will change the frequency dependent characteristics of the amplifier.
Patrick
Practically speaking, does that mean that the circuit would have to be completely reoptimized to add another pair of MOSFETS?
Looneytunes
Optimization is individual, even within a given design.
You can simply parallel output devices and it will work fine, but
if you tweak some of the resistor values, you can get the most out
of it. This is also true of the published circuit. Most examples meet
a .002% spec at 1 watt, but some run a little higher, and you can
tweak them down. Similarly with the bandwidth.
So if you have a scope and a distortion analyzer, you can always get
a little better.
a little better.
Thanks in advance.
CHeers.
Borko.
And THANK YOU for your kind generosity. As CHairman of the ETOOTL WORLD CAUCUS (EITHER TO OLD OR TO LAZY) I can tell you that ASSUMPTION to your particular Paradise is secure.
bongo99 said:Any PCB group buy for F5 yet?
Love to build one.
Betcha it happens!!!
- F5 power amplifier
