Input filter calculation
Seems to me, the resistor of the source is not part of the calculation for a high pass input filter. The source resistance should always be lower than the amps input resistance or so I thought.
.....from wikipedia
First-order continuous-time implementation
Figure 1: A passive, analog, first-order high-pass filter, realized by an RC circuit
The simple first-order electronic high-pass filter shown in Figure 1 is implemented by placing an input voltage across the series combination of a capacitor and a resistor and using the voltage across the resistor as an output. The product of the resistance and capacitance (R×C) is the time constant (τ); it is inversely proportional to the cutoff frequency fc, at which the output power is half the input power. That is,
where fc is in hertz, τ is in seconds, R is in ohms, and C is in farads.
.....from wikipedia
Insert a low value r between the Capacitor and the tapping point where the big R picks up.Seems to me, the resistor of the source is not part of the calculation for a high pass input filter. The source resistance should always be lower than the amps input resistance or so I thought.
.....from wikipedia
The smallr =1k0 and the bigR =100k in the F5.
The impedance seen into the jFETs is very high at audio frequencies.
For an F5 where r:R is 1:100 the effect of r is inaudible.
If the ratio r:R moves towards 1:1 (say 10k for both) the effect will be very audible. It is certainly not a zero effect.
Now add some RF filtering to the input by paralleling the 100k with a pF cap (c).
The audible effect of smallr becomes noticeable as the rc value increases.
If you think the Exicons, then the answer is yes.Has anyone tryed the following devices:
ECX10N20R nmos
ECX10P20R pmos Pairing
Fcrawley
If you think the F5 amp, then the answer is no.
I tried it with the P101 class AB amp from Rod Elliott. Excellent!
& for fun!
ECX10N20R nmos
Fcrawley
I have some on order, but I was not intending on using them in the F5. I was thinking of using them in BA2, plus a couple of my own designs.
Maybe this should not be posted here but, anyone thinking about a group buy on heatsinks for the F5. Maybe conrad.
I used Heatsink-USA. The 10.125" with 2.5" fins are perfect. I think mine are 8" long each...
Heatsink USA - diyAudio
What is the purpose of having a resistor to ground after the output cap of the preamp/dac? when you connect that capacitor output to power amp input, you are already providing that resistance to ground.Rin = R9+R10 = 101k
With the DAC 50K you have 1uF & 33k4
The F-1dB ~ 9Hz.
Try changing the 50k to something much higher.
Could you explain if there are any differences? Thanks Andrew
Bear,
you, I and other Members come to expect that many on this Forum do not read, cannot read or won't read !
It is frustrating.
Whoah, whoah, WHOAH! You want me to read? Next I suppose you'll ask me to pick up a soldering iron and do it myself!
Well I just wanted the "free" "typical food from my land..." or maybe I would find out that I didn't, but...
Anyhow reading is not all it is cracked up to be...
And, some people post and don't build, so there seems to be a fair yin/yang effect at work... at the present, I don't seem to be doing much of either posting or building, so I am safe in that regard...
Also, I don't actually know anything, despite any appearances to the contrary.
_-_-bear
_-_-bear
That comment is an extra large steaming pile of excrement.
Regards, Compressit
Ah, the perfect partner for an evening of kentucky straight at the counter.
I have made a little excel sheet with calculations for the F5 amplifier. For my own use.
Output power, Bias etc.
Maybe someone else can make use of it.
http://www.filesonic.com/file/44631579/F5_Amplifier_Calculations.xls
http://www.filesonic.com/file/44631585/F5_Amplifier_Calculations.ods
It would be easier to make a zip file and upload it here directly...I have made a little excel sheet....
- F5 power amplifier
