F5 power amplifier
diyAudio Chief Moderator
Joined 2002
Also, Salas, how does the DCB1 mate with the F5? I ask because I read that there could be issues connecting the DCB1 to an amp without an input cap, and the F5 is such a beast...
Many thanks
Some DCB1 builders told me that they mate extraordinarily well for SQ but I keep on warning them that they create a fully DC coupled chain from source to speaker that will send their woofers to kingdom come in any mishap. Its wise to compromise with a coupling cap between them. Or use a highly reliable DC sense and protection system on the amp's output.
If DC offset is under control to a very low range or using a DC servo circuit with it, I prefer not to compromise with a coupling cap. Any way to avoid adding back a coupling cap ? A cap make a DCB1 not DC anymore.
For the positive rail. The negative rail would not be as simple.
Yes it would. Tie two batteries in series and point of connection is your new ground, like this:
Joined 2002
Or it makes an F5 AC input. Offset is no problem with DCB1. Very low near zero, no wandering.
Safety first is to be advised in such situations. Although, we haven't heard of any DC failure on any Mez or Hypno yet. The disaster scenario is when some build will lose one reg, the opposite voltage is going to appear full on output. Also there are sources that can leak DC and it will pass, whatever.
The best way is a power output DC protection and delay relay scheme. That will guard speakers from any possible failure in the F5 too. Having a full DC path from source to speakers is another order of transparency I must admit.
I see. I would rather make the protection in the F5, like a speaker DC protection relay with high current contacts, than add a coupling cap either in the DCB1 or in the F5 for possible failure situation. I know some ones would say "no" to relay anyway. For transparency, I think a cap is worse than a DC protection relay.
Electro,
Class A amps without a budget, eh! I love it - my "wish list" gets bigger, .....
Adding a coupling cap (in series with signal) also requires a dc bias of a few volts across it and hence, back to a basic/standard B1.
The output relays are okay if you get the high current, twin contacts, low Z, etc and not the usual small dual things, plus good ccts for the dc protect, delay, mute, etc.
If the Power Amplifier is DC coupled, then I believe, it must have supplementary systems to protect the speakers.
DC servo to reduce output offset,
DC detect and activate speaker isolation,
Supply Rail isolation or fusing,
Input mute on excess DC, to reduce signal through the amp to help activation of output isolation.
Taken to extreme, you could use DC activated crowbar protection across the output and/or across the supply rails.
