http://www.diyaudio.com/forums/full-range/144211-alpair-6-bass-reflex-bookshelf-2.html#post1904699
You can also scale it up for a Alpair 7.
Patrick
Patrick
Would you recommend me some of the best price/performance woofer for F5 amplifier?(I think price range about 150$/pair)I bought Vifa XT25SC90-04 1" Dual Radiator Tweeters and now i need woofers.Thank you
These Scanspeak woofers match the efficiency of your tweeters and are 4 ohm so should be easy to design a crossover network. A steep slope will have to be used if choosing a 1000 hz crossover point. There are other offerings in a smaller woofer (7"-6"), depending on your choices for cabinet size.
No crossover required for the Alpair.
You can also make a easy box :
http://www.diyaudio.com/forums/twin...ts-mark-audio-alpair-7-full-range-driver.html
Patrick
Patrick
Alpairs seems good but i think they are less effeciency.I can not get enough bass with them.Though F5 amp is sensitive to room.I do not have a big room.
A little off thread perhaps???
Start a new thread in Loudspeakers either fullrange or multi.
Not trying to be an A&&, but you would be better served in a different forum.
Ron
I agree. I want to read about what others think about the F5's sound and their experience with said amp in this regard.
I think circlotron needs a more sophisticated PSU, since it has a worse PSRR.
Not if properly balanced. My circlotron with lateral MOSFETs had 200mV ripple per rail and none of the hum or noise (silent as F5).
That's a very nice piece. I like the 4131 with the local feedback.
Hi Nelson.Did you use amazing circlotron with ths4131?What do you think when comparing it with F5 amplifier?(about sound)Thank you
Thanks Mr. Pass, and not just for your kind comment, but for the design of this lovely sounding chip too
- F5 Listening Impressions & Discussion
