F5 amp transistor kit
Hi Hannes,
I received the four F5 kits and four F5T V3 kits. They were well packed and shipped quickly! All the Mosfets are matched to three decimal places. I can't wait to get the amps started. Thanks for the great service and communication. I would highly recommend anyone who needs matched transistors to go through you!
Thanks,
Steve
It was kindly indicated to me that some folks might be in need of a transistor kit for the F5 amp.
So here it is...
All transistors for one F5 channel:
1x IRFP240
1x IRFP9240
1x ZTX450
1x ZTX550
1x 2SK170BL (high power version of 2SK370)
1x 2SJ74BL (high power version of 2SJ108)
+enough Kerafol Keratherm heatpad for the 2 mosfets, the a little hard to get but truly excellent stuff recommended by EUVL (not precut, but rather easy to do yourself)
If two channels are ordered, the big mosfets come matched (matched between channels).
This kit I can offer for 15 Euros.
That should help a bit, the remaining hardware should be easy to obtain almost everywhere ;)
Happy building :flame:
Hi h_a :)
I need all transistors for two F5 channel`s.
How do I pay you?
Hi Thomas!
Nelson uses the same resistors for all jfets (BL-grade); I think Patrick (EUVL) suggested a trimming scheme that relies on resistor tuning to facilitate even harmonic distortion cancellation.
If that is what you refer to, than you're certainly safe with the original values. Tuning distortion cancellation is certainly nice, but not required.
Hannes
