carpenter said:another
I see a black heatsink with diodes. Are the diodes hot?
a.
carpenter said:Here's a Wakefield 392-300AG heatsink given to me from a fellow carpenter. He had no idea what it was, but thought I might be able to put it to good use.
I purchased a mate for it at a cost of $160.00. This will be my first F4. For the rest of the F4s, I'm going to play with water cooling.
Caps in PS are 47,000uF each.
Ugly!
(Choky will wait until you post a pic of a finished amp and present it in its full ugliness )
p.s. In the dark,it doesn't matter if its ugly or not, as long as it sounds good!
Vix said:p.s. In the dark,it doesn't matter if its ugly or not, as long as it sounds good!
So true; I've been told that the same can be said of the person in our bed, sleeping next to us...
Zen Mod said:woodie
please use metal screws for output fets ; these plastic ones are just begging for bubble gum effect ....... then pufff!
Wouldn't that actually be at least pufff, pufff, puff ?
Magura
Magura
next we'll see woodie's BFR91 amp ..............
carpenter said:You guys are funny...
Metal screw carry the fet tab through the mica and into the heatsink, thereby causing a direct short!
Which is why you use an insulator for the bolt
Really, the nylon bolts are going to give up the ghost sooner than you expect.
Magura
Magura
Well, now that you mention it, where do I get a screw kit that isolates that tab. I've been looking everywhere.
No idea, I just machined some of a piece of FR4 board, last time I needed those.
Magura
Re: Re: N to P matching
Thanks for info. I got similar result.
I measured Vgs with 20pcs each of IRFP240 and IRFP9240.
Luckily, I found that deviation of Vgs among each pieces was
not bad at all. And, the average absolute Vgs of IRFP9240 group
was about 0.17V higher than the average Vs of IRFP240 group.
By the way, did you use the original R of 22.1K between
the reference and cathode of TL431?
What is the Vdc measured between the gate of N-Mosfet
and the gate of P-Mosfet on the bias condition?
carpenter said:I'm using P channels that are 0.18 volts apart from the N channel...
I'm thinking about using a bar,.......
Might as well, it's the best way anyway
Did you check under the sofa
how do I know that when I'm living in Serbia?
look at CookBook - you'll see them on cover pics........
that's dreky nipple, nothing else
Magura
why I'm not surprised ?
- F4 power amplifier
