Predator864 said:For a dual mono how many boards I have to buy ?
A single amp board, consists of two amp channels separated by a scoring line.
For dual mono, or stereo, you will need one amp board (F3 or F4) and 2 PS pcbs for F4 and 1 PS for F3.
Re: Hiii
I will start collecting payments next week.
Pocoyo said:To Whom i must pay ?
vonfilm said:Can someone give me the link for the main building thread for the F3?I have searched, but have been unable to find it.
Try search on Zv9, those are basically same amps.
The power supply will work with all amps and also with line stages, digital circuits etc:
http://www.diyaudio.com/forums/showthread.php?postid=1237660#post1237660
http://www.diyaudio.com/forums/showthread.php?postid=1306941#post1306941
http://www.diyaudio.com/forums/showthread.php?postid=1316353#post1316353
http://www.diyaudio.com/forums/attachment.php?s=&postid=1237660&stamp=1182352931
Can only this part be made ?
Now I will have to edit wiki as I would nead 2PS PCB For F4 ( I was counting that I would nead 1 per (stereo-dual mono) AmpPCB )
@ Peter Daniel - will you send email to every one with billing cost (PCB+shiping+paypal fee) or should we just make payment and drop you email once we make it ?
Predator864 said:http://www.diyaudio.com/forums/attachment.php?s=&postid=1237660&stamp=1182352931
I'm pretty shure some of the people will use regular bridges so you might be able to find just this part.
yoke said:@ Peter Daniel - will you send email to every one with billing cost (PCB+shiping+paypal fee) or should we just make payment and drop you email once we make it ?
I will certainly not send any emails. Payment info will be posted in this thread, as it was done before: http://www.diyaudio.com/forums/showthread.php?postid=1298371#post1298371
Don't do any payments yet, as I'm waiting for price and order confirmation.
F3 layout:
http://www.diyaudio.com/forums/showthread.php?postid=1256218#post1256218
F4 layout:
http://www.diyaudio.com/forums/showthread.php?postid=1193264#post1193264
The amp that uses Zv9 boards (very similar to F3): http://www.diyaudio.com/forums/showthread.php?s=&threadid=85590&highlight=
F4 layout:
Peter Daniel
Ok, I am confused. I intend on building 2 stereo F3 amps and 4 balanced F4 monoblocks. I have ordered one PS board for each of the F3 boards(pairs). I also ordered PS board one PS board for each monoblock F4 board(pair). That means I ordered six PS boards, two F3 amp boards(pair), and four F4 amp boards(pair) to make the amps listed above. Is this correct or do I need two PS boards for each F4 board(pair) to make one balanced monoblock?
It is correct.
Think this way: F3 uses only one supply voltage, so a single PS board can be used either for stereo or dual mono implementation (as it has two section)
F4 uses symmetrical PS, so for stereo you'll need one PS board, but for dual mono, two PS boards (both PS sections are used per amp channel)
khundude said:So for a balanced F4 it is essentially two F4's. So just to be clear, one or two PS boards for each pair of F4 amp boards? I just want to be certain.
Yes. It is essentially two F4's. I use one power supply for each - using the V+ and V- wired to both boards. Ground is common to all of them. I can send you a picture of it assembled if you like.
Mike
- Group Buys
- F3 and F4 Clone PCB Reissue group buy, also F5 PCBs
