Thanks, for the kind words guys. Unfortunately, my soldering skills are not much better than some of you guys. So, I won't be selling any boards with premounted IC's. Anyway, if you want a board (or more), just send me an e-mail, let me know how many, and where you live in the world, and I'll send you the details.
I can personally recommend this place for SMD soldering work. They were helpful and prompt.
Tirna Electronics (ebay)
Dan
Dan
Re: CS4398
Nope, it is not pin compatible with PCM1794/8.
reddish75 said:would it be possible to use the CS4398 dac chip instead of the others?
thanks
chris
lauret said:Has anybody tried this DAC with 24/96 input? Do you have to reset it before you can input a 16/44.1 signal?
I tried it with the output of my DVD player. It works fine, and doesn't need a reset. But I had to press STOP and PLAY to make the input receiver lock to the new format.
Ray
6h5c said:A similar schematic can be found here. The values for the components I used are in the BOM.
Regards,
Ray
Thanks, but now I have another question. How is that power supply (the power supply for the flea) supposed to work? The transformer is 15V and the output 18VDC?
Thanks in advance,
Bart
lauret said:Thanks, but now I have another question. How is that power supply (the power supply for the flea) supposed to work? The transformer is 15V and the output 18VDC?
Thanks in advance,
Bart
Time for some basic electronics
http://www.st.com/stonline/books/pdf/docs/1707.pdf
The 15V is the RMS value at full load. If you don't load the transformer to the max, and take a big capacitor after the rectifier, the output voltage will be much higher.
Ray
Guys, here's a rough draft of some Construction Guidelines for the ezDAC. Please feel free to look it over and offer suggestions for improving it. I will probably add a section about adjusting the voltage on the regulators, but I haven't got to that yet.
i/v conversion
hi was poking around google researching ideas for a different i/v converter/output stage and found this as a good starting place for it http://members.chello.nl/~m.heijligers/DAChtml/Analogue/IV.html
chris
chris
Re: i/v conversion
Chris, you'll notice the final conclusion is the best sounding I/V is a resistor. Sound familiar?
BTW, I was reading a review of the Bel Canto DAC3 in Stereophile yesterday. According to the article (although I cannot seem to verify this), the DAC3 uses - you guessed it - a high quality resistor for I/V. That is followed by an op amp (presumably as a buffer). Seems very similar to what I have done with the ezDAC, which is sort of reassuring. They liked the sound of the DAC3, as well as the fact that it measures very well. I should note, that the DAC3 also uses CS8416 and ASRC is done by CS8421. The actual D/A is done by PCM1792. Looks like I have created a DAC3 clone of sorts.
reddish75 said:hi was poking around google researching ideas for a different i/v converter/output stage and found this as a good starting place for it http://members.chello.nl/~m.heijligers/DAChtml/Analogue/IV.html
chris
6h5c said:Hey, hey, the first parts are fitted!
Evan, this board is awesome! Very good 'solderability'
Ray
Looking very neat Ray! may I ask what solder you use?
- Digital Source
- EZDAC is singing now!!!
