Large Picture of ExaU21
Do you have a pic of the board that can be be (or is) magnified significantly so one can see where out board power supplies can be supplied?
Could you share with us how DSD can be interfaced with Buffalo-III?
2l has just posted a 5.1 channel demo DXD file - B.Britten: Simple Symphony, Op. 4 - Boisterous Bourrée
Oh, wonderful!
Who on earth has tried a multichannel play ( more than stereo) of DXD sources?
Sorry, exaU2I can be used only as a playback interface.May I also use this device as interface for my ADC?
Still waiting for DSD support for ExaU2i.... This will be the biggest step forward. Thanks for the good work!
We are working on basic DSD player based on Flemming's idea. So far we've managed to properly read and parse the DFF header and to read a clean DSD stream. At the present time we are implementing proper multi-threading and buffering. If we are lucky the player will be ready within a week.
I've also emailed the author of Allocator and I hope to be able to provide simplified direct integration between Allocator and the exaU2I software.
exa065
Hi George.
Have you got some news concerning the integration between exau2i and allocator?
Hi George.
I haven't received a reply from the Allocator people. However integration using a VST host is not a problem. Have you seen my experiments here - Using Allocator with exaU2I and Foobar 2000
Could you describe the configuration that you are interested in?
This one multichanel setup
O, this one . Have you bought the Buffalo II boards? Buffalo II is now discontinued and you can have eight channels with a single Buffalo III.
I`ve just received my ExaU2I today. Excited to hear the sounds, but unfortunately will take a little while until my the DACs will come too... I`m waiting for Buffalo 3, and I just have an idea to connect Exa to my (new and on the way too) Oppo BDP 95 (its audio board).
In mean while, I have some questions about Exa I`ve just got.
I can see on the board an CN1 place for an connector. What is this for and how eventually be used?
I can see too the ECS 11.2896Mhz oscillator on PCB. The ppm specifications for this device is 200. I personally think that this is huge in this kind of applications like Ultra HiFi. I mean this oscillator is a quite poor quality one. I do not know yet the ppm specification for the another quartz, but I can guess that is not at all under 50 ppm... I personally experienced the very big difference in playback music using an 100-50 ppm oscillator, against an 0,3 ppm one. An comment from ExaDevices in this respect will be welcome... By the way, someone with an idea about how to adapt an 5v oscillator to get 3,3v TTL compatible out of it (and off course, no negative consequences for the quality of the output frequency, jitter etc.) ?
I can not see on the Exa board an LED indicator for the max samplings frequency (384kHz). Will really work ExaU2I in this range?
Thanks for some comments...
Hi Coris,I`ve just received my ExaU2I today. Excited to hear the sounds, but unfortunately will take a little while until my the DACs will come too... I`m waiting for Buffalo 3, and I just have an idea to connect Exa to my (new and on the way too) Oppo BDP 95 (its audio board).
The CN1 connector has no user-accessible application.
Regarding the clocks - throughout this discussion we have been criticized many times for our minimalistic design approach. We believe that there is no point to over-engineer. I didn't make any difference in our judgement - based on subjective perception and measurements - to use more expensive components or design solutions. We felt that the design is balanced and fully accomplished as is. We felt it is unfair to add $50 cost without being able to quantify or hear the benefit.
I will be very grateful to get feedback from you on using different clocks. All the feedback from our users will be considered for the next version of the device. The current design was made originally for our own use. The next one will be based on the collective experience.
Could you suggest alternative oscillators? I haven't seen a 0.3 ppm clock.
Finally, the LED for 384 kHz is missing because this sampling frequency was added as a software update. Existing users were quite happy to get extra juice from their devices. Normally there are 3 lights on during playback - Power, FIFO and the rate indicator LED. At 384 kHz there are 2 lights on - Power and FIFO. This is a unique LED combination.
Another software upgrade is coming soon and this time we are really short on lights: DSD64 will be displayed as 44.1 kHz and DSD128 will come as 88.2 kHz.
- More Vendors...
- exaDevices
- exaU2I - Multi-Channel Asynchronous USB to I2S Interface
