Hi, AKSA,
How are you
Very good explenation, thank you. Don't get me wrong, I'm not suggesting that using slow, medium, fast is the only "right" way, I just suggesting Richie for an "experiment", since in post #39 he asked this :
I really think that you has conducted far more experiments than I do
How are you
If we are to use dominant cap, your explenation makes the sense, because external cap will be more linear than transistor's internal cap. But if we have intention not to use dominant cap, maybe we have to choose the transistors, cannot just use the fastest available.I wonder if using a slower transistor for VAS would mean I could use less compensation? I'm using a small-signal transistor in this position whereas pretty much every other design I've seen uses something low/medium-power. I've put everything away now, might try swapping the transistor another day when I got some more time.
from Lavardin's website:
Let's get serious again here. If you want to avoid capacitor dielectric distortion then use low distortion capacitors like polystyrene (for extremists air core is better, silk cores work well to) and avoid most ceramics. Or avoid the capacitor altogether and use a transistor with relatively high Ccb. The main reason that VAS stages almost always have a discrete capacitor is because Ccb is very Vcb sensitive and this makes it VERY non-linear. Ccb may often vary +/- 50% across the output swing. Other reasons include the need for high C and the need for a stable C value in production.
It is as simple as that.
Good grief!The memory distortion (1) of components is the greatest discovery in analog audio design over the last twenty years . It clearly demonstrates the reasons why a good valve amplifier can beat its solid state counterpart hands down for sheer musical enjoyment. Memory distortion is the property that is the dominent factor in causing solid state amplifiers to sound shrill and mechanical. Tube technology allows electrons to travel through a vacuum which causes no storage or memory effect, but solid-state amplifiers use silicon components which keeps the trace of electrons flux that have gone through .
Hi Traderbam,
I think yes. We can scotch this one from first principles.
The CB junction is reverse biased, so a depletion layer with moving charges within it exists at all times. The width of the depletion layer depends on Vce, of course, but also current.
Any semiconductor region which passes a current and yet has a large voltage across it has both capacitance and resistance. The flow of current and consequent existence of charge indicates that this region could be considered as a capacitor with very high dielectric absorption, OR as a resistor with very high capacitance, take your pick.....
In either scenario, the notions of capacitance and resistances are blurred, and it logically follows that dielectric absorption, which contributes principally to memory effect, is a real issue.
Do I lose my head?
Andrew, I agree, there are unexplained issues here. Why, if miller capacitance is so large and Cdom so small, are small increments in Cdom so influential on the sound quality?
David, all this is detective work. Alas, all I have is an inquiring mind and a good CRO, not much else. I have tried to relate topology and compensation issues to sound quality, and been moderately successful so far, but failed miserably in explaining in simple terms why these phenomenon take place.
Hugh
Hugh, am I infering correctly that you think that Ccb of a transistor suffers from dielectric absorbtion effects?
Do I lose my head?
Hugh
Workhorse said:Hi Richie,
Where's the secret Schematic of your amplifier....
regards,
K a n w a r
Just for you I have downloaded new software so that I can draw the full schematic. Still getting to grips with the software though...
I have decided to abandon the design anyway, as it inherently has a turn-on thump due to the input being at a slight voltage offset from ground. I'm trying to design a noiseless on/off amp.
Oh my dear Richie just for me,
Now it seems that you were dead serious, Meanwhile your circuit could be very well made to act as softstart type when turning on-off.....
K a n w a r
traderbam said:...........Ccb is very Vcb sensitive and this makes it VERY non-linear. Ccb may often vary +/- 50% across the output swing.....
Cascode required.
richie00boy said:I did download it, but got sidetracked on my new amp. The new amp is not quite noiseless on/off but it's better than the 'current feedback' one in this thread. I'll try and get round to drawing it out for you.
Where is your schematic.....Richie Rich....
Who is owner of this schematic?
powerbecker said:lumanauw:
" Is it "current mirror with gain" like Blomley?"
hello lumanauw,
no, it´s more like Hegglun (EW1995)
Heinz!
Broken Promises
I am still waiting for your schematic.......Richie....
richie00boy said:I did download it, but got sidetracked on my new amp. I'll try and get round to drawing it out for you.
richie00boy said:He he I thought you had forgotten about it. I'll see what I can find.
How could i forgot you...after all you are just like my younger brother Richie...[remember something]
I sent you e-mail.
forr said:Hi Viktor,
For schematics of either Blomley or Hegglun 1995 or both, email me.
I sent you e-mail.
I have just designed an output stage with hybrid bjt-mosfet (BD139/40 2SK1530/2SJ201) using Sziklai topology with relatively low distortion based on simulation results and was planning to make my first prototype soon. I did expect a straightforward build until i read this forum.
Any experience or advise?
- Ever made a MOSFET CFP/Sziklai that works?
